Component: Photo Reflector 2D (Light)
Revision as of 17:29, 16 January 2023 by Wiki bot (talk | contribs)
Category Light
Photo Reflector 2D component
Uses InfraRed light to detect if an external object is near to the sensor. Returns a discrete analogue signal which can represent distance from the nearest object. Useful for applications like wall following, control based systems and robotics.
Please click here for the component source code: FC_Comp_Source_PhotoReflector_2d.fcfx
Fc9-comp-macro.png SampleSensor
Samples the sensor and automatically controls the emitter pin if enabled. Returns the analogue reading from the sensor pin.
Fc9-comp-macro.png Initialise
Sets up the I/O to allow the sensor to operate.
Fc9-type-16-icon.png Emitter Type
Decides if the emitter needs to be switched on and off during sampling
Fc9-type-6-icon.png Sense Pin
Pin connected to the sensor element of the photo transistor
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Discrete Distance
Simulation range used to determine if the sense pin is active or not.
