Component: Visi (4DSystems) (Comms: System)
Revision as of 14:09, 20 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category Comms: System
Visi (4DSystems) component
A way of interacting with the VISI interface designed by 4D systems. VISI firmware must be pre-loaded onto the SD card connected to the display to allow everything to work correctly.
Please click here for the component source code: FC_Comp_Source_API_Display_Visi4D.fcfx
Fc9-comp-macro.png VisiWriteString
Writes a string to a specific Visi object. Returns 0 for a succesful write operation.
Fc9-u8-icon.png - BYTE StringIndex
Fc9-string-icon.png - STRING StringData
Fc9-comp-macro.png VisiWriteObject
Writes a value to a specific Visi object. Returns 0 for a succesful write operation.
Fc9-u8-icon.png - BYTE ObjectID
Fc9-u8-icon.png - BYTE ObjectIndex
Fc9-u16-icon.png - UINT Value
Fc9-comp-macro.png ChangeHWBaud
Changes the hardware UART baud rate allowing for dynamic speed changes.
Fc9-u8-icon.png - BYTE NewBaud
Fc9-comp-macro.png VisiReceive
Waits for an incoming Visi Report Object or Report Event to be sent from the display. A detected incoming message returns 0 and can be read using the VisiReadByteFromMessage macro.
Fc9-comp-macro.png VisiWriteContrast
Updates the display contrast. Returns 0 for a succesful write operation.
Fc9-u8-icon.png - BYTE Contrast
Range 0-15, 0=Backlight Off
Fc9-comp-macro.png VisiWriteVolume
Updates the display volume. Returns 0 for a succesful write operation.
Fc9-u8-icon.png - BYTE Volume
Range 8-127
Fc9-comp-macro.png VisiReadByteFromMessage
Reads a byte from a succesful VisiReceive macro. Index: 0=Command, 1=ObjectID, 2=ObjectIndex, 3=ValueMSB, 4=ValueLSB
Fc9-u8-icon.png - BYTE Index
Fc9-comp-macro.png VisiReadObject
Reads the value from a specific Visi object. Returns 0 for a sucessful read. Use the VisiReadByteFromMessage macro to pull out the incoming data.
Fc9-comp-macro.png Initialise
Sets up the RS232 peripheral, must be called at the start of your program or at least before you start calling any other RS232 macros.
Fc9-conn-icon.png Comms Settings
Fc9-type-16-icon.png Channel
Fc9-type-16-icon.png Baud Options
Fc9-type-5-icon.png TX
Fc9-type-5-icon.png RX
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Label shown on the communications flasher component
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
