Component: Accelerometer 3-Axis (MMA8452Q) (Movement Orientation)
Revision as of 14:09, 20 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category Movement Orientation
Accelerometer 3-Axis (MMA8452Q) component
MMA8452Q Accelerometer sensor with I2C. Useful for approximating Pitch and Roll or for detecting acceleration.
Please click here for the component source code: FC_Comp_Source_Accelerometer_MMA8452Q.fcfx
Read_Register
Reads a value from a register on the accelerometer.
- BYTE Reg
Register address to read from
SimReset1G
Resets the simulation to 0.0 on X and Y and 1.0 on Z as if the accelerometer was sitting completely horizontal.
Write_Register
Writes a data value to a specific register on the accelerometer
- BYTE Reg
Register Address to Write to
- BYTE Data
Value to write to the register
CollectXYZData
Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
- BYTE Axis
- INT Return
UpdateXYZData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
Read_N_Registers
Reads a set of data values from sequential registers on the accelerometer
- BYTE Start_Reg
First address to read data from
- BYTE Num_Regs
Number of registers to read
- BYTE data
Data variable to populate with the register values
SimSetXYZ
Allows the XYZ slider values to be set via the simulation
- INT X
- INT Y
- INT Z
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
Bit Depth
The number of binary bits used to store the sensor's X,Y,Z readings.
Scale
The accelerometer readings are scaled based on the maximum amount of G force the sensor can represent. 6G = Bigger gravitational force 2G = Higher resolution
Data Rate
Int Option
Sets if we use the interrupt pin to check if new data is available
Device Address
I2C Connections
Channel selection
Baud Select
Baud rate to be used
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
Simulate Comms
Yes: Accelerometer data will come from the simulation component sliders. No: Accelerometer data will come from the CAL component - I2C or SPI - API etc
