Component: GLCD Monochrome (BL0139) (E-blocks 2)
Revision as of 14:10, 20 January 2023 by Wiki bot (talk | contribs)
Category E-blocks 2
GLCD Monochrome component
Graphical display component designed to work with the EB2 BL0139 Downstream E-block.
Please click here for the component source code: FC_Comp_Source_EBlocks2_Mono_GLCD_BL0139.fcfx
ReadFontWidth
- BYTE Font
- BYTE Character
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- BYTE X1
- BYTE Y1
- BYTE X2
- BYTE Y2
Write_Data
- BYTE data
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Goto_XY
- BYTE X
- BYTE Y
Plot
- BYTE X1
- BYTE Y1
SetDisplayOrientation
- BYTE Orientation
BPlot
- BYTE X1
- BYTE Y1
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ClearDisplay
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
Write_Command
- BYTE Command
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
DrawRectangle
- BYTE X1
- BYTE Y1
- BYTE X2
- BYTE Y2
- BYTE Transparent
- BYTE Solid
Version
Dimensions
Pixel Height
Pixel Width
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
CS
Chip select pin
Reset
A0
Data Pin
Clock Pin
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Display Method
Component Label
Component Label Scale
