Component: File (RPI) (File)
Revision as of 14:11, 20 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.7
Category File
File (RPI) component
File component allowing access to read and write files on the Raspberry Pi file system.
Please click here for the component source code: FC_Comp_Source_File_RPI.fcfx
ReadStringFromFile
Reads a string from the currently open file. Auto increments the position in the file. An empty string signifies the end of the file has been reached.
- UINT NumBytes
Maximum number of bytes to attempt to read
- BYTE EndChar
Ends the string if the value specified is found, default is 0
- STRING Return
MoveToNextFileSector
Not currently implemented on the RPI
- BYTE ForceNextSector
WriteByteToBuffer
- UINT Address
- BYTE Data
AppendByteToFile
- BYTE Data
CloseFile
ReadByteFromFile
Reads a byte from the currently open file. Auto increments the position in the file. A return value of 0 may signify the end of the file has been reached (depending on the contents of the file).
ReadByteFromIndex
Reads a byte of data from the local sector buffer. Return = Data byte read from the local sector buffer.
- ULONG Address
DeleteFile
- STRING Filename
CreateFile
- STRING Filename
OpenFolder
- STRING Folder_Name
ReadFileLength
- INT Return
OpenFile
Searches for and opens a file for reading or writing from within the current directory on the disk. Returns 0 for success.
- STRING Filename
8.3 filename of the file we are trying to open e.g. "file.txt"
WriteFileSector
SetFileIndex
- BYTE File_Index
Range: 0 to 4
AppendStringToFile
- STRING Data_String
ReadFileSize
Reads the entire size of the current file in bytes.
- ULONG Return
Root Folder
Root location on the RPI where the files will be stored
File Count
Number of simultaneous files we want to access.
Sim Root Folder
