Component: Injector (API Analog Input) (Test Injectors)
Revision as of 14:11, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Test Injectors
Injector (API Analog Input) component
Data injector to allow a physical analog input pin to be attached to a simulated component. The component will poll for any input state changes via SCADA Slave enabled hardware. Enabling the Flowcode simulation runtime to directly interface with a physical I/O pin.
Please click here for the component source code: FC_Comp_Source_InjectorSCADAAnalogInput.fcfx
InitialiseInjector
- STRING InjectorName
RxByteCount
Returns the number of bytes currently sat in the receive buffer.
TxByte
- BYTE DataByte
RxByte
GetConsoleHandle
- HANDLE Return
API Slave
Number of Pins
Specifies the number of pins the component can monitor and control.
Poll Rate
Pin 0
Simulation ADC Pin
Pin monitored by the simulation
SCADA Slave ADC Pin
Pin used by the connected SCADA Slave hardware
