Component: LCD (Electronic Assembly) (Alphanumeric)
Revision as of 14:12, 20 January 2023 by Wiki bot (talk | contribs)
Version 2.1
Category Alphanumeric
LCD (Electronic Assembly) component
Generic configurable alphanumeric LCD display component based on the OLED Hitachi like display controller ICs from Electronic Assembly wiith selectable 4/8 bit interface. These have a very slight timing difference from the standard Hitachi displays.
Please click here for the component source code: FC_Comp_Source_LCD-W162-XBLW.fcfx
Fc9-comp-macro.png Clear
Fc9-comp-macro.png PrintString
Enter the text or variable to print to the LCD
Fc9-comp-macro.png PrintAscii
Fc9-u8-icon.png - BYTE character
Holds an ascii value.
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
Fc9-s16-icon.png - INT Number
Fc9-comp-macro.png RAMWrite
Fc9-u8-icon.png - BYTE Index
Values 0 to 7
Fc9-u8-icon.png - BYTE d0
Fc9-u8-icon.png - BYTE d1
Fc9-u8-icon.png - BYTE d2
Fc9-u8-icon.png - BYTE d3
Fc9-u8-icon.png - BYTE d4
Fc9-u8-icon.png - BYTE d5
Fc9-u8-icon.png - BYTE d6
Fc9-u8-icon.png - BYTE d7
Fc9-comp-macro.png ClearLine
Fc9-u8-icon.png - BYTE Line
The line to clear, zero being the first (top) line of the display
Fc9-comp-macro.png Cursor
Fc9-u8-icon.png - BYTE x
Set the cursor position in the X plane, 0 is the left most cell
Fc9-u8-icon.png - BYTE y
Set the cursor position in the Y plane, 0 is the top most cell
Fc9-comp-macro.png Command
Fc9-u8-icon.png - BYTE instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
Fc9-comp-macro.png PrintFormattedNumber
Fc9-u32-icon.png - ULONG Number
Fc9-bool-icon.png - BOOL Format
0=Signed, 1=Unsigned
Fc9-comp-macro.png ScrollDisplay
Fc9-u8-icon.png - BYTE Position
Holds the number of positions to shift the display
Fc9-u8-icon.png - BYTE direction
0 = left, 1 = right
Fc9-comp-macro.png RawSend
Sends data to the LCD display
Fc9-u8-icon.png - BYTE data
The data byte to send to the LCD
Fc9-bool-icon.png - BOOL type
A boolean to indicate command type: true to write data, false to write a command
Fc9-comp-macro.png PrintFloat
Fc9-f32-icon.png - FLOAT Number
Fc9-u8-icon.png - BYTE DecimalPlaces
Fc9-comp-macro.png Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Fc9-type-16-icon.png Interface mode
Choose between 4-bit mode, 8-bit mode and 8-bit mode using a port instead of individual pins to improve code efficiency.
Fc9-type-5-icon.png Data 0 (11 / 7)
Data pin 0 - Connects to Data 4 on the hardware in 4-bit mode or Data 0 in 8-bit mode
Fc9-type-5-icon.png Data 1 (12 / 8)
Data pin 1 - Connects to Data 5 on the hardware in 4-bit mode or Data 1 in 8-bit mode
Fc9-type-5-icon.png Data 2 (13 / 9)
Data pin 2 - Connects to Data 6 on the hardware in 4-bit mode or Data 2 in 8-bit mode
Fc9-type-5-icon.png Data 3 (14 / 10)
Data pin 3 - Connects to Data 7 on the hardware in 4-bit mode or Data 3 in 8-bit mode
Fc9-type-5-icon.png Register Select (4)
Register Select Pin - Informs the display if a command or data is about to be sent.
Fc9-type-5-icon.png Enable (6)
Enable pin - Used to synchronise data writes to the display
Fc9-type-7-icon.png Use Read/Write Pin
Set to "true" if the displays R/W pin is not hard wired. Set to "false" if the R/W pin is wired to ground.
Fc9-conn-icon.png Display Settings
Fc9-type-16-icon.png Rows
Number of lines of characters the LCD can display.
Fc9-type-16-icon.png Columns
Number of characters the LCD can display on a single line.
Fc9-conn-icon.png Display Simulation
Fc9-type-15-icon.png Component Label Scale
Fc9-type-1-icon.png Text Colour
Colour of the font characters drawn on the display
Fc9-type-1-icon.png Text Background
Colour surrounding the font characters drawn on the display
Fc9-type-1-icon.png Display Background
Colour of the background of the display
