Component: MIAC (PIC) (Misc)
| Author | Matrix Ltd |
| Version | 1.7 |
| Category | Misc |
MIAC (PIC) component
MIAC - Matrix Industrial Automotive Controller PLC type module based on a PIC18F4455 device, produced by Matrix Component includes functions to drive the functionality of the MIAC and MIAC system.
Please click here for the component source code: FC_Comp_Source_MIAC.fcfx
Analogue Input
Basic example of how to read an analogue input on the MIAC and display it on the LCD.
MIAC ADC LCD
Keypad Input
Basic example of how to read the keypad and display the value on the LCD.
MIAC Keypad
For reference the numbering of the MIAC keypad looks like this.
Output Control
Basic example of how to control all of the individual outputs on the MIAC using the keypad.
Note that for the transistor outputs to come on you must wire a connection from the +V terminal to the M terminal.
If you are driving high current outputs then you can instead supply separate DC power to the M terminal.
MIAC Outputs
MIAC Interrupt Controlled Clock
Basic example of how to create a timer interrupt based clock.
MIAC Clock
| InputANALOG_10Bit | |
| Returns the 10 bit value for the analogue input requested by parameter InputID (Inputs 1 to 8) | |
| InputID | |
| The input to read from 1 to 8. | |
| RelayOFF | |
| Turns off the requested relay given by parameter RelayID, values 1 to 4 | |
| RelayID | |
| The relay to turn off. From 1 to 4. | |
| PrintString | |
| Prints the given character string to the display at the current cursor position and moves the cursor position. | |
| Str | |
| The string to send to the display. | |
| GetKeypad | |
| Returns the key code of the key that is pressed, otherwise if nothing is pressed then returns 255 | |
| DisplayStart | |
| Initialise the display ready for use | |
| DisplayCommand | |
| Sends the given command to the display | |
| Cmd | |
| PrintASCII | |
| Prints the given character to the display at the current cursor position and increments the cursor position. | |
| Char | |
| ASCII code of the character to print. | |
| PrintNumber | |
| Prints the given number to the display starting at the current cursor position and moves the cursor position. | |
| n | |
| DisplayClear | |
| Clears the display to white space | |
| RelayON | |
| Turns on the requested relay given by parameter RelayID, values 1 to 4 | |
| RelayID | |
| The relay to turn on from 1 to 4. | |
| OutputOFF | |
| Outputs a digital low state on the output requested by parameter TransID (Outputs 1 to 4) | |
| TransID | |
| 1 to 4 (Outputs A to D) | |
| OutputON | |
| Outputs a digital high state on the output requested by parameter TransID (Outputs 1 to 4) | |
| TransID | |
| InputDIGITAL | |
| Returns the digital state of the input requested by parameter InputID (Inputs 1 to 8) | |
| InputID | |
| The input number from 1 to 8. | |
| InputANALOG | |
| Returns the 8 bit value for the analogue input requested by parameter InputID (Inputs 1 to 8) | |
| InputID | |
| Properties |
