Component: Sense Hat (Raspberry Pi Hat)
Revision as of 14:13, 20 January 2023 by Wiki bot (talk | contribs)
Category Raspberry Pi Hat
Sense Hat component
A component to drive various features on the Raspberry Pi Sense Hat. Supported Features: 8x8 RGB LED / 5-Way Joystick
Please click here for the component source code: FC_Comp_Source_RPI_SenseHat.fcfx
A simple example to sample the joystick and output a fixed colour to all 8 x 8 RGB LEDs. Pressing up on the joystick outputs blue to the LEDs and pressing down outputs red.
RPI Sense HAT
ReadJoystick
Reads the joystick Returns the direction as a bit field. 1 = Down / 2 = Right / 4 = Up / 8 = Click / 16 = Left
SetPixel
Seta the colour of a single pixel
- BYTE X
- BYTE Y
- BYTE R
- BYTE G
- BYTE B
SetAll
Sets all pixels to a specific colour
- BYTE R
- BYTE G
- BYTE B
Initialises the I2C peripheral ready for communications.
I2C
Channel selection
SDA
SCL
Stop Delay
Baud Select
Baud rate to be used
API
