Component: SPI Slave (Comms: Interface)
Revision as of 14:13, 20 January 2023 by Wiki bot (talk | contribs)
Category Comms: Interface
SPI Slave component
Low level routines for controlling or interacting with an SPI interface. SPI or Serial Peripheral Interface is a bus used for board level communications between devices. A target microcontroller will usually have at least one hardware SPI peripheral built in.
Please click here for the component source code: FC_Comp_Source_SPI_Slave.fcfx
Simple Master program that sends an incrementing test value to the SPI bus as well as outputting the value onto LEDs.
SPI_Master
Simple Slave program that collects the value sent by the master and outputs the value onto LEDs. Allows the master slave comms to be compared to check that everything is working correctly.
SPI_Slave
Another simple example to buffer incoming SPI bytes sent by the master and output these to the LCD.
SPI_Slave2
SendChar
General purpose SPI send byte macro
- BYTE Char
Data byte to send
GetChar
General purpose SPI get byte macro
UnInitialise
Deactivates the SPI peripheral leaving the I/O pins in a state where they can be used for general purpose I/O.
Activates the SPI peripheral and claims control over the I/O pins.
SPI Channel selector
MOSI
MISO
CLK
Use Slave Select
CS / SS
Bus Settings
Clock Phase
Clock Polarity
Sample Point
Data bit read sample point
Label used to identify the component on the panel.
API
