API Panel.Position.MoveTo
<sidebar>API contents</sidebar> Moves the object to the given coordinates relative to its parent
HANDLE Handle
FLOAT X
- Local coordinate X to update with
FLOAT Y
- Local coordinate Y to update with
FLOAT Z
- Local coordinate Z to update with
- Add to a calculation icon:
::Panel.Position.MoveTo(handle, x, y, z)
Flowcode example file
From the SimulationAPIExamples folder load SIMAPI_Panel_Position_MoveTo.fcf file into Flowcode. In this example, there are three cubiods that represent Axis X,Y,Z. Note they are coloured exactly as the panel axis indicator which represents your viewing position. There is a sphere also on the panel.
The MoveTo(h,x,y,z) function moves the object specified to a new set of coordinates. In the example file, the program moves the sphere from it's original location of x10,y10,z0 to x100,y75,z0, waits a second and then moves the sphere back to it's original coordinates.
The screenshots below show the effect and also highlight the code used by the example.
