Component: XML JSON Parser (Runtime Tools)
Jump to navigationJump to searchAuthor | MatrixTSL |
Version | 1.0 |
Category | Runtime Tools |
XML JSON Parser component
A component designed to simplify the collection of data from XML and JSON sources. Parses the raw data and creates a dynamic representation of the data that is easy to navigate and interrogate. Also allows the objects to be manually created or edited and then re-exported as XML or JSON format.
Please click here for the component source code: FC_Comp_Source_XMLParser.fcfx
SetObjectString |
Sets the data string of an existing object. | |
Object |
Handle to the object | |
Data |
Return |
GetRootHandle |
Allows for user to step through the objects manually using the inbuilt runtime api calls. | |
Return |
FindObject |
Finds the first instance of an object. Returns the first matching path from the root. Returns 0 if the path was not found. | |
ObjPath |
e.g. "rss.channel.title" | |
Return |
FindObjectString |
Searches for and then collects the data string from the specified path. Returns the first matching path from the root. | |
ObjPath |
Return |
GetObjectString |
Collects the data string from the specified object. | |
Object |
Return |
ClearObjects |
Deletes all object data ready for fresh input | |
Return |
GetObjectTag |
Collects the tag string from the specified object. | |
Object |
Return |
BuildXMLString |
Generate a XML string based on the current objects inside the component. | |
Return |
DeleteObject |
Deletes a selected tag object. | |
Object |
Return |
FindNextObjectString |
Searches for and then collects the data string from the specified path. Returns the first matching path from the last search | |
SubObjPath |
e.g. "item.title" | |
Return |
BuildJSONString |
Generate a JSON string based on the current objects inside the component. | |
Return |
SetObjectTag |
Sets the tag name of an existing object. | |
Object |
Tag |
Return |
Properties |
