Component: LED (LES, Panel) ()
| Author | Matrix Ltd |
| Version | 1.3 |
| Category |
LED (LES, Panel) component
Panel lamp for a LES bulb. Colour can be changed in component properties.
Please click here for the component source code: FC_Comp_Source_lamp_les.fcfx
