Component: Potentiometer (Trimmer) ()
Revision as of 14:14, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.4
Category
Potentiometer (Trimmer) component
Trim Pot for 0.1mm pitch PCB. With finger dial knob. Pointer colour can be changed from component properties.
Please click here for the component source code: FC_Comp_Source_pot_Trimmer.fcfx
FC6 Icon.png Potentiometer Example
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Start Angle
Fc9-type-15-icon.png Sweep Angle
Fc9-type-1-icon.png Color
Fc9-type-7-icon.png Retain Value
If yes is slected After saving your project, the ADC value will be retained when your project is reloaded.
Fc9-type-15-icon.png Set Value
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
