Component: Infrared Array AMG88xx (Light)
Revision as of 15:12, 20 January 2023 by Wiki bot (talk | contribs)
Category Light
Infrared Array AMG88xx component
An 8x8 (64) Pixel infrared sensor array allowing basic none contact temperature detection.
Please click here to view the component source code (Beta): FC_Comp_Source_AMG88.fcfx
SetMovingAverageMode
Set the moving average mode on or off.
- BOOL Mode
0 = Off, 1 = On
ClearInterrupt
Clear any triggered interrupts
SetInterruptMode
Set the interrupt to either absolute value or difference mode
- BOOL Mode
0 = Difference / 1 = Absolute
SetInterrupt
Allows the interrupt pin to be enabled or disabled.
- BOOL Mode
0 = Disabled / 1 = Enabled
SetInterruptLevels
Set the interrupt levels. Interrupt when going above High or interrupt when going below Low.
- FLOAT High
Range: -1023 to 1023
- FLOAT Low
- FLOAT Hysteresis
Range: -1023 to 1023 ( Recommend 0.95 * High )
SamplePixels
Reads Infrared sensor values
ReadThermistor
Reads the onboard thermistor Returns the temperature in degrees Celsius as a floating point value
- FLOAT Return
ReadPixel
Reads the temperature of a single pixel value from the last SamplePixels call.
- BYTE Index
Pixel to read. Range: 0 - 63
- FLOAT Return
Sets up the I2C interface and initialises the sensor.
Address
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
API
- BOOL Mode
0 = Off, 1 = On
ClearInterrupt
SetInterruptMode
- BOOL Mode
SetInterrupt
- BOOL Mode
SetInterruptLevels
- FLOAT High
- FLOAT Low
- FLOAT Hysteresis
SamplePixels
ReadThermistor
- FLOAT Return
ReadPixel
- BYTE Index
- FLOAT Return
Address
Channel selection
SDA
SCL
Baud Select
Stop Delay
API
