Author
Matrix Ltd
Version
2.0
Category
Graphical Color
GLCD (4D Goldelox) component
Graphical display component designed to work with the Goldelox range of displays from 4D Systems.
Please click here to view the component source code (Beta): FC_Comp_Source_API_Display_4D_Goldelox.fcfx
G4D_InitialiseCard
Initialises the micro SD card inserted into the module is available. Returns 0 for succesful initialisation or 255 for a detected failure. Does not currently simulate.
- BYTE
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
Size of the font - 0 = Normal, 1 = Double Width, 2 = Double Width and Height, 3 = Double Height
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
FastPlot
G4D_DisplayVideoFromCard
Attempts to display a sequence of images from the micro SD card at the specified address location on the card. The images are printed at location starting from X, Y and ranging to Width, Height.
- UINT
X
- UINT
Y
- UINT
AddH
- UINT
AddL
- BYTE
BPlot
- UINT
X1
- UINT
Y1
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
G4D_ReadJoystickGoldelox
Reads the value of the joystick input. 0 = No press detected / 1 = Up Pressed / 2 = Left Pressed / 3 = Down Pressed / 4 = Right Pressed / 5 = Fire Pressed
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
SetBackgroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
G4D_DisplayImageFromCard
Attempts to print an image from the micro SD card at the specified address location on the card. The image is printed at location starting from X, Y and ranging to Width, Height.
- UINT
X
- UINT
Y
- UINT
AddH
Byte Address High Word
- UINT
AddL
Byte Address Low Word
- BYTE
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Dimensions
Pixel Height
Pixel Width
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
TX
RX
Reset Pin
Reset pin connection
Baud Options
Component Label
Component Label Scale
Physical Orientation
Console Columns
Data Source
G4D_InitialiseCard
- BYTE
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
FastPlot
- UINT
X
- UINT
Y
- UINT
AddH
- UINT
AddL
- BYTE
BPlot
- UINT
X1
- UINT
Y1
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
SetBackgroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
- UINT
X
- UINT
Y
- UINT
AddH
- UINT
AddL
- BYTE
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Dimensions
Pixel Height
Pixel Width
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
TX
RX
Reset Pin
Baud Options
Component Label
Console Columns
Data Source
