Component: Ambient Light (BH1750FVI) (Light)
Revision as of 15:13, 20 January 2023 by Wiki bot (talk | contribs)
Category Light
Ambient Light component
A small PCB surface mount ambient light sensor with a I2C bus interface. Spectral responsibility is approximately human eye response. Wide range and High resolution. ( 1 - 65535 lx )
Please click here to view the component source code (Beta): FC_Comp_Source_AmbientLight_BH1750FVI.fcfx
ContinuousMeasurement
Powers up and starts the continous measurement mode. Delays in between measurements readings must be provided by the user,
- BYTE Resolution
0=1lx (120ms) / 1=0.5lx (120ms) / 2 = 4lx (16ms)
OneTimeMeasurement
Powers up and starts a single measurement before returning to power down mode. Waits for the measurement to be ready and returns the value.
- BYTE Resolution
PowerDown
Power Down the Device
ChangeMeasurementTime
Adjusts the measurement result to counteract influence of the optical window.
- BYTE Sensitvity
Range: 31-254 / Default: 69
ReadMeasurement
Reads data from the Light Sensor as a 16-bit value.
ResetMeasurement
Resets the device measurement register, Must be in the powered up state to do this.
Stes up the I2C bus and initialises the termperature sensor ready for use.
I2C Properties
Slave Address
Channel selection
SDA
SCL
DVI Pin
Pin used to reset the device.
Baud Select
Baud rate to be used
Stop Delay
Simulate Comms
- BYTE Resolution
OneTimeMeasurement
- BYTE Resolution
PowerDown
- BYTE Sensitvity
ReadMeasurement
ResetMeasurement
I2C Properties
Slave Address
Channel selection
SDA
SCL
DVI Pin
Baud Select
Stop Delay
Simulate Comms
