Component: Base 64 (Calculation)
Revision as of 15:13, 20 January 2023 by Wiki bot (talk | contribs)
Category Calculation
Base 64 component
Component to allow base 64 encoding and decoding. Sometimes when communicating raw binary data it is useful to perform base 64 encoding to ensure that none of your data bytes trigger any escape codes or other special case conditions. Base64 converts your binary data into readable data using standard ASCII characters so you can be fairly certain that the data you send is the same as the data that is received.
Please click here to view the component source code (Beta): FC_Comp_Source_Base64.fcfx
Here is a basic example that shows how to convert data into base64 encoded data and visa versa. Base64 Tests
Encode
Encodes an array of bytes into a base64 encoded string
- BYTE BinaryData
Raw binary data array you wish to encode
- UINT ByteCount
Number of bytes of data to encode
- STRING Return
Decode
Decodes a base64 encoded string into an array of bytes. Populates the BinaryData parameter array with the decoded data. Returns the number of decoded data bytes.
- BYTE BinaryData
Variable to hold the decoded binary data
- STRING Base64Data
Data string you wish to decode
Encode
- BYTE BinaryData
- UINT ByteCount
- STRING Return
Decode
- BYTE BinaryData
- STRING Base64Data
