Component: CSV Read/Write (File)
Revision as of 15:13, 20 January 2023 by Wiki bot (talk | contribs)
Category File
CSV Read/Write component
A component to simplify the task of creating and dumping data to a CSV file that can be loaded into Microcoft Excel or LibreOffice Math to create nice charts and graphs. Requires one of the File components to provide access to the file system.
Please click here to view the component source code (Beta): FC_Comp_Source_CSV_Writer.fcfx
Simple example file to generate a two column CSV file that can be loaded into Microsoft Excel or LibreOffice Math.
CSV Component used with Embedded -> File SD component: CSV Test
CSV Component used with Embedded -> File RPI component: CSV Test RPI
CSV Component used with App Developer -> File component: CSV Test AD
The component requires linking to a File component to provide access to the file system for simulation and runtime, this could be the File SD, File RPI or File AppDeveloper components.
CloseFile
Closes the file and finishes off any pending writes ready for use in an external application.
SequentialReadString
Reads the contents of a cell as a string. Automatically moved to the next data cell after a read.
- STRING Return
AddString
Adds a string to the CSV followed by a comma. This will form a single column of data in the CSV file.
- STRING data
ReadAsString
- UINT Column
- UINT Row
- STRING Return
SequentialReadNumber
Reads the contents of a cell as a number. Automatically moved to the next data cell after a read.
- FLOAT Return
AddNumber
Adds a number to the CSV followed by a comma. This will form a single column of data in the CSV file.
- FLOAT data
ReadAsNumber
- UINT Column
- UINT Row
- FLOAT Return
SetSequentialIndex
Sets the index for sequential reads. Index is automatically reset to 0 after a file open.
- UINT Index
OpenFile
Creates or opens a file ready for streaming data. If the file already exists then the contents will be deleted and the file started again from scratch. Returns 1 if file found and opened.
- STRING Filename
- BOOL Erase
0=Append existing data, 1=Reset file data
- BOOL Return
NextRow
Move to the next row in the file
LinkTo
CloseFile
- STRING Return
AddString
- STRING data
ReadAsString
- UINT Column
- UINT Row
- STRING Return
- FLOAT Return
AddNumber
- FLOAT data
ReadAsNumber
- UINT Column
- UINT Row
- FLOAT Return
SetSequentialIndex
- UINT Index
OpenFile
- STRING Filename
- BOOL Erase
- BOOL Return
NextRow
LinkTo
