Component: Ultrasonic (EBM019) (EBM Modules)
Author | Matrix TSL |
Version | 1.0 |
Category | EBM Modules |
Ultrasonic component
This board has both an ultrasonic transmitter and receiver. The transmitter is driven by an on-board 40KHz oscillator which is enabled by the host microprocessor. The receiving sensor signal is amplified and provided as an analogue signal to be processed by a single channel ADC of the microprocessor. By measuring the time delay between enabling a transmit pulse and receiving an echo the distance of objects in a range of around 3cm to 3m can be determined.
Please click here to view the component source code (Beta): FC_Comp_Source_EBM019v1.fcfx
Sample program using the EBM019 - Ultrasonic sensor.
Sends out a pulse and determines distance from time taken to receive reflection.
GetDistance |
Sends a pulse and processes the echo. Returns a object distance in cm | |
Return |
SetDelayTime |
Set the delay time before sampling for the echo, in microseconds | |
delay |
delay time in microseconds | |
Return |
SetDetectionValue |
Set the delta value for echo detection | |
value |
trigger point for echo detection | |
Return |
SetPulseWidth |
Set the output pulse width, in microsecond (0-255uS) | |
pulse |
width of pulse in microseconds | |
Return |
Initialise |
Setup the device. This sets the control output to logic 0 | |
Return |
GetDistance |
Return |
SetDelayTime |
delay |
Return |
SetDetectionValue |
value |
Return |
SetPulseWidth |
pulse |
Return |
Initialise |
Return |
