| Author
MatrixTSL
| Version
1.0
| Category
Analog Input
ADC (MCP356X) component
An external ADC featuring 2, 4, or 8 channel 24-bit input. Capable of reading each channel independently or in differential mode. Communication using an SPI bus up to 20MHz.
Please click here to view the component source code (Beta): FC_Comp_Source_ExternalADC_MCP356X.fcfx
SetOffsetCalibration
| Allows the device offset to be entered allowing for accurate readings.
- LONG
Offset
SetGainCalibration
- ULONG
Gain
| Default 800000 = Gain of 1X
SampleADC
| Performs a single ADC sample and returns the result as a 24-bit value
- BYTE
PositiveChannel
| 0=CH0 - 7=CH7, 8=GND, 9=VDD, 11=REF+, 12=REF-, 13=TP, 14=TM, 15=VCM
- BYTE
NegativeChannel
- LONG
| Confgures the SPI bus ready for communications and initialises the MCP356X device. Returns true if device is responding to commands.
- BOOL
Device Configuration
Device Type
Device Address
| These bits are fixed from the manufacturer and by default are 01. Used as Bits 6 and 7 of the command byte. Alternative bits must be requested from the manufacturer.
Clock Selection
Sensor Bias Current
ADC Bias Current
AMCLK Prescaler
Oversampling Ratio
ADC Gain
IRQ Mode
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MOSI Remap Pin
| Select which the target pin to assign the MOSI hardware pin functionality.
MISO
MISO Remap Pin
| Select which the target pin to assign the MISO hardware pin functionality.
CLK
CLK Remap Pin
| Select which the target pin to assign the CLK hardware pin functionality.
CS / SS
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
Use IRQ
| No: Use polling of the status register to determine when an ADC sample is complete. Yes: Use the IRQ interrupt pin to determine when an ADC sample is complete.
Simulate Comms
| No: Simulation is done using panel sliders. Yes: Send SPI data via API interface and show real time data using panel sliders.
- LONG
Offset
SetGainCalibration
- ULONG
Gain
SampleADC
- BYTE
PositiveChannel
- BYTE
NegativeChannel
- LONG
- BOOL
Device Type
Device Address
Clock Selection
Sensor Bias Current
ADC Bias Current
AMCLK Prescaler
Oversampling Ratio
ADC Gain
IRQ Mode
Prescale
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
CS / SS
Use IRQ
Simulate Comms
