Component: HBRIDGE (CAL) (Misc)
Version | 2.1 |
Category | Misc |
HBRIDGE component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the H-Bridge peripheral. Currently only supports compatible 8-bit PIC devices.
Please click here to view the component source code (Beta): FC_Comp_Source_HBRIDGE.fcfx
Half Bridge Application
A Half Bridge type output has two output signals A and B.
Full Bridge Application
Full Bridge type output has four output signals A, B, C and D.
A simple proof of concept example to drive a full bridge output with varying speed and direction.
GetValue |
Returns Named property Value | |
Name |
Return |
Disable |
Disable this PWM Channel | |
Return |
Enable |
Enable this PWM Channel | |
Return |
SetSpeed |
Sets the motor speed by varying the PWM duty. | |
duty |
Duty value 0 - 1023 | |
Return |
SetValue |
Sets the Value of the property PERIOD, PRESCALE or CHANNEL (if CHANNEL also updates the PORT from FCD) | |
Name |
Value |
Return |
SetDirection |
Set the motor direction. | |
direction |
0 = Forwards, 1 = Reverse | |
Return |
GetList |
Returns CHANNEL or PRESCALE list from the FCD and updates the internal property | |
Name |
Return |
GetValue |
Name |
Return |
Disable |
Return |
Enable |
Return |
SetSpeed |
duty |
Return |
SetValue |
Name |
Value |
Return |
SetDirection |
direction |
Return |
GetList |
Name |
Return |
