Component: LED (3mm, PCB) ()
Revision as of 15:15, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category
LED (3mm, PCB) component
An industry standard 3mm diameter LED. Any color may be chosen, and the leads trimmed to length.
Please click here to view the component source code (Beta): FC_Comp_Source_LED_3mm.fcfx
LED Resistor Calculator Tool
Pin
Chip pin to connect the LED to.
Polarity
Active High: Pin true -> On color, Pin false -> Off color Active Low: Pin true -> Off color, Pin false -> On color
Color
The color of the LED when it is turned on.
Trim Leads
Trim the length of the two leads. Length cannot be less than 3.0, or greater than the length as supplied.
Show
Decide what labels to show... None - no labels are displayed Name - shows each component's name Property - shows a particular property of each component (see 'property' below.
Property
Show a particular property of each object. If a port or pin property is chosen, the label can be abbreviated to remove the '$PORT' text.
Color
Color of the labels text.
Scale
Sets the basic size (text height) of the labels.
Follow Zoom
Whether labels get bigger and smaller when the panel is zoomed in and out.
Position
Position of the label relative to tehe component
Pin
Polarity
Color
Trim Leads
Show
Property
Color
Scale
Follow Zoom
Position
