Component: Barometer (BMP180) (Environmental)
| Version | 1.1 |
| Category | Environmental |
Barometer (BMP180) component
Barometric pressure sensor with a I2C bus interface. Pressure range 300 to 1100 hPa. Temperature range -40 to +85 °C.
Please click here to view the component source code (Beta): FC_Comp_Source_Pressure_Sensor_BMP180.fcfx
| ReadPressureFloat | |
| Reads the pressure as a floating point value in Bars. Calls the ReadPressureRaw function and then converts to a meaningful value. | |
| Reset | |
| Resets the device | |
| I2C_Read_Register | |
| Reads a byte value from a register on the device | |
| Address | |
| Altitude | |
| Calculates the altitude based on difference between actual pressure and the pressure at the sea level P0=1013.25 hPa. | |
| Forced_Read | |
| I2C_Write_Register | |
| Writes a byte value to a register on the device | |
| Address | |
| Value | |
| Starts up the I2C bus and initialises the pressure sensor ready for use. Returns 1 for a sucessful startup. Returns 0 for a failed startup or no device detected. | |
| Reset | |
| Address | |
| Altitude | |
| Forced_Read | |
| Address | |
| Value | |
