| Author
MatrixTSL
| Version
1.0
| Category
Misc Circuit
RGB Xmas Tree component
Component complete with macros and simultion to drive the MatrixTSL RGB Xmas Tree decoration.
Please click here to view the component source code (Beta): FC_Comp_Source_XmasTree.fcfx
For more information please refer to the Xmas Tree blog post.
PlayNote
| Plays a specific note for the length of time specified.
- BYTE
Note
| 0-59 - 0=C, 1=C#, 2=D, 3=Eb, 4=E, 5=F, 6=F#, 7=G, 8=G#, 9=A, 10=Bb, 11=B, 12=C...
- UINT
Length
WaitAudio
| Checks to see if the audio circuit is current outputting a tone. If it is then the macro will wait until the audio is free again.
- UINT
Delay
| Optional ms delay after the audio has stopped playing 0=No Delay
SetColours
| Generates a colour value based on the input colour parameters and asigns it to all of the LEDs.
- BYTE
Red
| Red 0=None, 255=Max
- BYTE
Green
| Green 0=None, 255=Max
- BYTE
Blue
| Blue 0=None, 255=Max
RandomLED
| Randomises the colour to a specific LED
- BYTE
LED
| LED 0 to NumLEDs - 1
MoveToColour
| Generates a colour value based on the input colour parameters and transitions one of the LEDs to the new colour. Remains in the function until the new colour has been reached.
- BYTE
LED
- BYTE
Red
| Red 0=None, 255=Max
- BYTE
Green
- BYTE
Blue
- UINT
TransistionDelay
| Delay in milliseconds between each transition
SetLED
| Directly sets the colour of a single LED. Red = 3-bit, Green = 3-bit, Blue = 2-bit 0bBBGGGRRR
- BYTE
LED
- BYTE
Colour
JingleBells
| Plays the Jingle Bells tune using the audio driver.
SetLEDs
| Sets the colour of all the LEDs. Red = 3-bit, Green = 3-bit, Blue = 2-bit 0bBBGGGRRR
- BYTE
Colour
CheckSwitch
| Checks to see if the switch is pressed. Returns 1 to indicate a press and 0 to indicate not pressed.
- BYTE
SetColour
| Generates a colour value based on the input colour parameters and asigns it to one of the LEDs.
- BYTE
LED
- BYTE
Red
| Red 0=None, 255=Max
- BYTE
Green
- BYTE
Blue
CheckAudio
| Checks to see if the audio circuit is current outputting a tone. Returns 1 to indicate audio active and 0 to indicate not active.
- BYTE
RandomLEDs
| Randomises the colour of all the LEDs
GetLED
| Directly read the colour of a single LED. Red = 3-bit, Green = 3-bit, Blue = 2-bit 0bBBGGGRRR
- BYTE
LED
- BYTE
| Starts up the LED PWM and Audio software driver.
Pin Connections
LED Data Port
LED Clock Pin
LED Enable Pin
Audio Output Pin
Switch Input Pin
LED Properties
Number Buffers
| Number of octal buffer IC's you will require to drive the LEDs. Note that the microcontroller data port provides the first buffer so the numbr of ICs is actually one less than the value shown.
Number LEDs
Test On Startup
| Performs a simple LED test routine on start up. LEDs should all light up white, red, green and blue in second intervals.
PlayNote
- BYTE
Note
- UINT
Length
WaitAudio
- UINT
Delay
SetColours
- BYTE
Red
| Red 0=None, 255=Max
- BYTE
Green
- BYTE
Blue
RandomLED
- BYTE
LED
MoveToColour
- BYTE
LED
- BYTE
Red
| Red 0=None, 255=Max
- BYTE
Green
- BYTE
Blue
- UINT
TransistionDelay
SetLED
- BYTE
LED
- BYTE
Colour
JingleBells
SetLEDs
- BYTE
Colour
CheckSwitch
- BYTE
SetColour
- BYTE
LED
- BYTE
Red
| Red 0=None, 255=Max
- BYTE
Green
- BYTE
Blue
CheckAudio
- BYTE
RandomLEDs
GetLED
- BYTE
LED
- BYTE
Pin Connections
LED Data Port
LED Clock Pin
LED Enable Pin
Audio Output Pin
Switch Input Pin
LED Properties
Number Buffers
Number LEDs
Test On Startup
