Component: Switch (Toggle, PCB) ()
| Author | Matrix Ltd |
| Version | 1.1 |
| Category |
Switch (Toggle, PCB) component
Miniature toggle switch with metal tang. Pins for PCB mounting.
Please click here to view the component source code (Beta): FC_Comp_Source_sw_toggle_pcb.fcfx
Switch
(5V / 11K) * 10K = 4.54545V
