Component: Accelerometer 3-Axis (MMA8452Q) (Movement Orientation)
Revision as of 15:20, 20 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category Movement Orientation
Accelerometer 3-Axis (MMA8452Q) component
MMA8452Q Accelerometer sensor with I2C. Useful for approximating Pitch and Roll or for detecting acceleration.
Please click here to download the component source project: FC_Comp_Source_Accelerometer_MMA8452Q.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Accelerometer_MMA8452Q.fcfx
Fc9-comp-macro.png Read_Register
Reads a value from a register on the accelerometer.
Fc9-u8-icon.png - BYTE Reg
Register address to read from
Fc9-comp-macro.png SimReset1G
Resets the simulation to 0.0 on X and Y and 1.0 on Z as if the accelerometer was sitting completely horizontal.
Fc9-comp-macro.png Write_Register
Writes a data value to a specific register on the accelerometer
Register Address to Write to
Fc9-u8-icon.png - BYTE Data
Value to write to the register
Fc9-comp-macro.png CollectXYZData
Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
Fc9-u8-icon.png - BYTE Axis
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png UpdateXYZData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
Fc9-comp-macro.png Read_N_Registers
Reads a set of data values from sequential registers on the accelerometer
Fc9-u8-icon.png - BYTE Start_Reg
First address to read data from
Fc9-u8-icon.png - BYTE Num_Regs
Number of registers to read
Fc9-u8-icon.png - BYTE data
Data variable to populate with the register values
Fc9-comp-macro.png SimSetXYZ
Allows the XYZ slider values to be set via the simulation
Fc9-s16-icon.png - INT X
Fc9-s16-icon.png - INT Y
Fc9-s16-icon.png - INT Z
Fc9-comp-macro.png Initialise
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
The number of binary bits used to store the sensor's X,Y,Z readings.
Fc9-type-16-icon.png Scale
The accelerometer readings are scaled based on the maximum amount of G force the sensor can represent. 6G = Bigger gravitational force 2G = Higher resolution
Fc9-type-16-icon.png Data Rate
Fc9-type-16-icon.png Int Option
Sets if we use the interrupt pin to check if new data is available
Fc9-type-16-icon.png Device Address
Fc9-conn-icon.png I2C Connections
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-16-icon.png SDA Remap Pin
Fc9-type-5-icon.png SCL
Fc9-type-16-icon.png SCL Remap Pin
Fc9-conn-icon.png Simulation
Yes: Accelerometer data will come from the simulation component sliders. No: Accelerometer data will come from the CAL component - I2C or SPI - API etc
Channel selection
Channel selection
