Component: Car Seat (Scenarios)
Revision as of 15:20, 20 January 2023 by Wiki bot (talk | contribs)
Category Scenarios
Car Seat component
An electric car seat chassis with a series of motors and sensors. Students should work through exercises to learn the principles of electric car seats including how to save and load memory positions.
Please click here to download the component source project: FC_Comp_Source_CarSeatSource_v004.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CarSeatSource_v004.fcfx
Car Seat Scenario
Fc9-comp-macro.png Save
Saves the current position of the seat into the allocated save slot.
Fc9-u8-icon.png - BYTE SavePos
0 = pos A, 1 = pos B
Fc9-comp-macro.png Load
Moves the seat back into the last saved position stored in the allocated save slot.
Fc9-u8-icon.png - BYTE Location
0 = A, 1 = B
Fc9-comp-macro.png Encoder3
Returns value is equal to Rear Z Axis current value.
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png Encoder2
Returns value is equal to Front Z Axis current value.
Fc9-comp-macro.png Encoder1
Returns value is equal to X Axis current value (forward/ backwards movement).
Fc9-comp-macro.png CurrentSenseMotor3
This macro is used to sense the current draw from DC motor 3. When it is not being used, it will draw no current. In normal operating conditions it will draw 3A, and under stall conditions (when the motor hits the end stops) it will draw 20A.
Fc9-comp-macro.png Motor3
Controls the Movement of the seat going up and down by the back
Fc9-u8-icon.png - BYTE Direction
0 = Stop, 1 = Up, 2 = Down
Fc9-comp-macro.png CurrentSenseMotor2
This macro is used to sense the current draw from DC motor 2. When it is not being used, it will draw no current. In normal operating conditions it will draw 3A, and under stall conditions (when the motor hits the end stops) it will draw 20A.
Fc9-comp-macro.png Motor2
Controls the Movement of the seat going up and down by the front
Fc9-comp-macro.png CurrentSenseMotor1
This macro is used to sense the current draw from DC motor 1. When it is not being used, it will draw no current. In normal operating conditions it will draw 3A, and under stall conditions (when the motor hits the end stops) it will draw 20A.
Fc9-comp-macro.png Motor1
Moves the Car Seat Forwards and Backwards
0 = Stop, 1 = Forward, 2 = Backward
Fc9-type-16-icon.png Show seat base?
Controls if the base of the car seat is shown on the simulation panel.
0 = A, 1 = B
0 = A, 1 = B
