Component: DMX-512 Slave (Comms: System)
Revision as of 15:20, 20 January 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Version 2.0
Category Comms: System
DMX-512 Slave component
A serial based communications protocol designed for controlling theatrical equipment such as dimmers, fog machines and intelligent lights. DMX-512 Slave devices are daisy chained together with a final 180R terminating resistor at the end of the chail. DMX requires the signal to be level shifted from VCC and GND to +2.5V and -2.5V.
Please click here to download the component source project: FC_Comp_Source_DMX-512_Slave.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DMX-512_Slave.fcfx
DMX Slave Example, captures the first DMX data channel sent from the Master and outputs the value onto a Port using the LED array component. DMX Slave Example1
For DMX 512 Master example see DMX Master
GetDataChannel
Gets the data byte from a data channel
- UINT Channel
ReceiveDataChain
Waits for a BREAK, MAB and StartCode followed by the contents of the data channels. Returns 0 to indicate a timeout and 1 to indicate succesful reception.
- BYTE Timeout
0 = Don't wait, 1 - 254 = 1ms - 254ms, 255 = Wait forever
Configures the UART serial interface.
Serial Properties
RX
Baud Options
DMX Properties
Data Channels
Number of data bytes to receive from the master, Max 512 bytes per transmission. 24 Bytes minimum from Master to match minimum 1204us timing requirements, not all channels need to be used.
Start Channel
Channel from the master which we want to start taking our data channels
Use Start Code
Do we wait for the start code or simply begin receiving data?
Start Code
Start code value to listen out for, range 0-255
Console Columns
Data Source
GetDataChannel
- UINT Channel
ReceiveDataChain
- BYTE Timeout
Serial Properties
RX
Baud Options
DMX Properties
Data Channels
Start Channel
Use Start Code
Start Code
Console Columns
Data Source
GetDataChannel
- UINT Channel
ReceiveDataChain
- BYTE Timeout
Serial Properties
RX
Baud Options
DMX Properties
Data Channels
Start Channel
Use Start Code
Start Code
Console Columns
Data Source
