Component: Fast Fourier Transform (FFT) (DSP Operators)
Revision as of 15:20, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Operators
Fast Fourier Transform (FFT) component
Provides a way of converting a buffer full of time domain data into frequency domain data. The output of the FFT is a set of frequency bins which correspond to the frequencies present in the signal. The number of frequency bins is equal to half the input buffer size with each bin being responsible for a portion of the frequency up to 1/2 the nyquist.
Please click here to download the component source project: FC_Comp_Source_DSP_FFT.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_FFT.fcfx
Example takes two adjustable frequency sine wave inputs and combines them and then passes the collection of 256 samples to the FFT function which produces 128 individual frequency banks which are then plotted from left (lowest frequency) to right (highest frequency) using an XY chart component.
FC6 Icon.png FFT Example
Frequency output for a set of data
Frequency banks can be worked out by using the sample frequency and buffer size. The number of frequency banks is equal to the number of samples divided by 2 minus 1. We subtract the one because bank 0 is always empty and so can be discounted.
FrequencyBanks = (SampleCount / 2) - 1
The frequency ranges present inside a bank can be worked out as follows.
FreqMin = ((SampleRate / 2) / (SampleCount / 2)) * Bank
FreqMax = ((SampleRate / 2) / (SampleCount / 2)) * (Bank + 1)
For example if we sample at 10KHz and collect 256 samples then frequency bank 10 would represent any frequencies in the range of 390.6Hz to 429.7Hz.
Here is a spreadsheet document that will calculate the frequencies present in each bank. The highlighted green fields are editable and will update the rest of the values.
File:FFT Frequency Bank Calculator.xls
Fc9-comp-macro.png ReadFrequencyBank
Reads the value from one of the frequency banks after the FFT conversion has been performed. Valid frequency banks range from 1 to the allocated buffer size / 2 assuming the buffers are sized to be equal to a power of 2.
Fc9-u16-icon.png - UINT BankIdx
Fc9-comp-macro.png FFT
Performs the data conversion from time based data to frequency based data. Takes a full buffer input and converts it into real and imaginary frequency data ready for you to read the individual frequency bins.
Fc9-comp-macro.png QueueData
Takes a single value from the buffer input and stores it, once there are enough values queued up it returns a 1.
Fc9-bool-icon.png - BOOL ProcessWhenFull
0 = Do Nothing when Buffer is full, 1 = Auto call FFT macro when Buffer is full
Fc9-type-16-icon.png Connect To
Number of individual elements the buffer can store, must be a power of 2, default 256.
Fc9-type-16-icon.png Buffer Type
Sets the buffer data type.
Fc9-type-7-icon.png Filter Input Data
Applies a hamming window filter to the time domain sample data to provide better frequency detection.
Fc9-conn-icon.png Calculations
Fc9-type-15-icon.png Sample Rate
Sample rate used to perform simple calculations like nyquist and bin size.
Fc9-type-15-icon.png Nyquist Frequency
The maximum frequency that can theoretically be detected by the FFT component assuming the sample rate is setup correctly.
Fc9-type-14-icon.png Frequency Bin Count
The number of frequency bins that the component will provide.
Fc9-type-15-icon.png Frequency Bin Size (Hz)
The frequency range covered by each frequency bin.
