Component: Median (DSP Operators)
Revision as of 15:20, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Operators
Median component
Collects the median value removing any potential high frequency spikes in the data.
Please click here to download the component source project: FC_Comp_Source_DSP_Median.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Median.fcfx
MedianArray
Passes an entire buffer through the median buffer and spits out a filtered version of the data at the other end
Median
Passes a single value from a DSP buffer into the median buffer and spits out a median value at the other end
Connect To
Buffer Size
Buffer Type
Sets the buffer data type.
Direction
Sets the data direction flow of the component
Median Array
Median Array Size
The number of values to combine together to create the median effect. Default 5. The higher the number the more immune to spikes the data will be. A larger array requires more processing to order. Minimum 3, maximum 255.
MedianArray
Median
Connect To
Buffer Size
Buffer Type
Direction
Median Array
Median Array Size
MedianArray
Median
Connect To
Buffer Size
Buffer Type
Direction
Median Array
Median Array Size
