Author
MatrixTSL
Version
1.0
Category
EEPROM
EEPROM (DS28E07) component
A rugged EEPROM allowing one or more devices to be addressed and accessed. Requires a One Wire component to perform the bus operations.
Please click here to download the component source project: FC_Comp_Source_EEPROM_DS28E07.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EEPROM_DS28E07.fcfx
SetString
Writes a string to the EE memory starting at the selected address. All bytes from the string will be written including the null termination.
- UINT
Address
Address of the value to write
- STRING
Value
Data string to write
GetString
Gets a string from the specified start address.
- UINT
Address
Address of the first data byte
- BYTE
MaxLength
Maximum number of bytes in the string, also includes null termination byte
- STRING
SetByteArray
Writes an array of bytes to the EE memory.
- UINT
Address
Starting address of the first value to write
- BYTE
Data
- BYTE
Count
Number of bytes to write to the EE memory, Range: 1 to 128 bytes
SetInt
Writes a 16-bit value to the EE memory. For consecutive 16-bit values the address must be incremented by 2.
- UINT
Address
- UINT
Value
16-bit value to write
- BOOL
MSBFirst
0: LSB is the first byte, 1: MSB is the first byte
AddressSpecificDevice
Starts a temperature conversion on a specific device using a hex string identifier. SerialNumber parameter should be 12 characters and contain the 48-bit Serial.
- STRING
SerialNumber
48-bit Serial Number e.g. "32DF4A3C1901"
GetSerialString
Gets the Serial String for the current addressed device.
- STRING
AddressNextDevice
Scans for the next connected device with a matching family code. Goes through the device list generated by the ScanBus macro.
SetLong
Writes a 32-bit value to the EE memory. For consecutive 32-bit values the address must be incremented by 4.
- UINT
Address
- ULONG
Value
32-bit value to write
- BOOL
MSBFirst
GetFloat
Reads a 32-bit floating point value starting from the specified byte address. For consecutive float values the address must be incremented by 4.
- INT
Address
The starting byte address
- BOOL
MSBFirst
- FLOAT
GetLong
Reads a 32-bit value starting from the specified byte address. For consecutive 32-bit values the address must be incremented by 4.
- INT
Address
- BOOL
MSBFirst
- ULONG
GetInt
Reads a 16-bit value starting from the specified byte address. For consecutive 16-bit values the address must be incremented by 2.
- INT
Address
- BOOL
MSBFirst
- UINT
GetByteArray
Reads an array of bytes starting from the selected address.
- UINT
Address
Starting address of the first value to read
- BYTE
Data
Byte array to store incoming data
- UINT
Count
Number of bytes to read from the EE memory, Range: 1 to 128 bytes
SetByte
Writes a single byte to the EE memory.
- UINT
Address
- BYTE
Data
GetByte
Reads a single byte from the selected address.
- UINT
Address
Address of the value to read
- BYTE
SetFloat
Writes a 32-bit floating point value to the EE memory. For consecutive float values the address must be incremented by 4.
- UINT
Address
- FLOAT
Value
Floating point value to write
- BOOL
MSBFirst
Configures each matching sensor on the bus with the specified conversion bits.
One Wire Component
Link to the one wire component to host the bus.
EEPROM Size (Bytes)
Simulate Comms
No - We use the panel GUI to perform the simulation. Yes - We use OneWire comms via an API to communicate with real hardware.
Panel Simulation
Number EE Devices
Sens the number of sensors we can communicate with during simulation
Serial 0
Serial number for simulated one wire device
SetString
- UINT
Address
- STRING
Value
GetString
- UINT
Address
- BYTE
MaxLength
- STRING
SetByteArray
- UINT
Address
- BYTE
Data
- BYTE
Count
SetInt
- UINT
Address
- UINT
Value
- BOOL
MSBFirst
- STRING
SerialNumber
GetSerialString
- STRING
AddressNextDevice
SetLong
- UINT
Address
- ULONG
Value
- BOOL
MSBFirst
GetFloat
- INT
Address
- BOOL
MSBFirst
- FLOAT
GetLong
- INT
Address
- BOOL
MSBFirst
- ULONG
GetInt
- INT
Address
- BOOL
MSBFirst
- UINT
GetByteArray
- UINT
Address
- BYTE
Data
- UINT
Count
SetByte
- UINT
Address
- BYTE
Data
GetByte
- UINT
Address
- BYTE
SetFloat
- UINT
Address
- FLOAT
Value
- BOOL
MSBFirst
One Wire Component
EEPROM Size (Bytes)
Simulate Comms
Panel Simulation
Number EE Devices
Serial 0
SetString
- UINT
Address
- STRING
Value
GetString
- UINT
Address
- BYTE
MaxLength
- STRING
SetByteArray
- UINT
Address
- BYTE
Data
- BYTE
Count
SetInt
- UINT
Address
- UINT
Value
- BOOL
MSBFirst
- STRING
SerialNumber
GetSerialString
- STRING
AddressNextDevice
SetLong
- UINT
Address
- ULONG
Value
- BOOL
MSBFirst
GetFloat
- INT
Address
- BOOL
MSBFirst
- FLOAT
GetLong
- INT
Address
- BOOL
MSBFirst
- ULONG
GetInt
- INT
Address
- BOOL
MSBFirst
- UINT
GetByteArray
- UINT
Address
- BYTE
Data
- UINT
Count
SetByte
- UINT
Address
- BYTE
Data
GetByte
- UINT
Address
- BYTE
SetFloat
- UINT
Address
- FLOAT
Value
- BOOL
MSBFirst
One Wire Component
EEPROM Size (Bytes)
Simulate Comms
Panel Simulation
Number EE Devices
Serial 0
