Component: DSP Audio Input (EB085) (E-blocks 1)
Revision as of 15:21, 20 January 2023 by Wiki bot (talk | contribs)
Category E-blocks 1
DSP Audio Input (EB085) component
16-bit external ADC connected to the microcontroller using SPI.
Please click here to download the component source project: FC_Comp_Source_ExternalADC_AD7680_EB085.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ExternalADC_AD7680_EB085.fcfx
SampleADC
Reads the ADC and returns the reading as an unsigned 16-bit value. Range: 0-65535 / 0=0V / 65535=VCC
Initialise the SPI bus ready for communications,
SPI Properties
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Data Recorder Trace
Simulate Comms
SampleADC
SPI Properties
Prescale
MOSI
MISO
CLK
CS / SS
Data Recorder Trace
Simulate Comms
SampleADC
SPI Properties
Prescale
MOSI
MISO
CLK
CS / SS
Data Recorder Trace
Simulate Comms
