Component: Formula AllCode Dummy (RB4420) (Mechatronics)
Revision as of 15:21, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Mechatronics
Formula AllCode Dummy component
A component to allow all the features of the Formula AllCode robot to be investigated. Fully simulated component which can interact with simulated objects on the panel as well as control the real hardware.
Please click here to download the component source project: FC_Comp_Source_FA_Source_P4_Dummy_Template.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_FA_Source_P4_Dummy_Template.fcfx
Line Following
Line following example using the Formula AllCode, works with objects on the simulation panel and on the real hardware.
FA-Line
Simulation with the API component
An example showing how to use the API component to drive the robot in simulation.
FA API Sim Demo
PlayNote
Outputs a single tone from the onboard speaker for the period specified.
- UINT Note
Sets the pitch of the note in Hz. Range: 1 - 10000
- UINT Time
Time period to play the note for in milliseconds. Range: 0 - 65535 ms
LEDOn
Switches on a single LED on the front of the Formula Allcode.
- BYTE LED
Which LED to switch on, range 0-7
BluetoothTransmit
Sends a byte via the Bluetooth data connection.
- BYTE Data
LCDPrintString
Prints a string to the graphical LCD.
- BYTE X
The horizontal start pixel. Range 0-127
- BYTE Y
Y coordinate to print the string. Range 0-31
- STRING Data
- UINT Transparent
Stop
Stops both motors.
ReadBattery
Reads the current voltage level from the LiPo battery. Return value is the battery voltage in Volts. Take care not to run the battery too low. Voltages lower than 3.4V may damage the battery.
- FLOAT Return
LEDOff
Switches off a single LED on the front of the Formula Allcode.
- BYTE LED
LCDPrintNumber
Prints a numeric value to the graphical LCD.
- BYTE X
- BYTE Y
- UINT Number
- BYTE Transparent
LEDWrite
Allows control of all 8-LEDs on the front of the Formula Allcode.
- BYTE LED_Byte
8-bit binary value to write to the 8 LEDs
BluetoothCheckConnection
Checks the status of the Bluetooth connection. Returns 0 for not paired and 1 for paired.
ReadMic
Reads the current audio signal level from the on-board microphone. Return value range: 0 to 4095
AudioQueueLength
Retreives the current length of valid data within the audio queue
AudioAddToBuffer
Writes a value to the 16-bit audio output buffer.
- UINT Data
ReadSwitch
Reads the value of one of the switches from the front of the Formula Allcode.
- BYTE Switch
Which switch do we want to read 0=Left, 1=Right
CheckLine
Checks to see if a line sensor is within the master threshold distance. Returns 0 if the IR reading is below the threshold. Returns 1 if the IR reading is greater than or equal to the threshold.
- BYTE Sensor
Range: 0 to 1 - 0=Left, 1=Right
AudioStreamControl
Allows control of the audio output functionality via the onboard speaker. Data is loaded into the audio output buffer using the AddToBuffer function.
- BYTE Mode
0=Off, 8=8-bit Mode, 16=16-bit Mode
- BYTE SampleRate
Sets the sample rate 0=8KHz, 1=16KHz
SpinLeft
Spins the formula flowcode on the spot in an anticlockwise direction as seen from above.
- BYTE Power
Amount of power to use to drive motor. Range 0-100
LogoTurnLeft
Rotates the robot left by a specific angle using the encoders as feedback to ensure the robot turns evenly. Automatically stops at the specified turn angle.
- UINT Angle
Angle in degrees you wish to rotate. Range 1-65536
Forward
Drives both motors of the formula flowcode forwards with the power specified.
- BYTE Power
LCDWriteByte
- BYTE Data
- BYTE X
- BYTE Y
BluetoothReceive
Attempt to read a byte from the Bluetooth receive queue.
LCDDrawLine
Draws a line on the LCD.
- BYTE X1
Range 0-127
- BYTE Y1
Range 0-31
- BYTE X2
Range 0-127
- BYTE Y2
Range 0-31
BluetoothQueueLength
Reads the length of received Bluetooth data in bytes.
BluetoothTransmitString
Sends a string via the Bluetooth data connection.
- STRING Data
LCDBacklight
Controls the brighness of the LCD backlight
- BYTE Brightness
Range: 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness
AudioReadFromBuffer
Allows the audio buffer to be used for other streaming data such as recording the mic.
ReadLineSensor
Reads the analogue value from the specified IR line sensor. Return value range: 0 to 4095 4095 represents the object is reflecting the most light.
- BYTE Channel
LogoTurnRight
Rotates the robot right by a specific angle using the encoders as feedback to ensure the robot turns evenly. Automatically stops at the specified turn angle.
- UINT Angle
SpinRight
Spins the formula flowcode on the spot in a clockwise direction as seen from above.
- BYTE Power
CheckIR
Checks to see if a IR sensor is within the master threshold distance. Returns 0 if the IR reading is below the threshold. Returns 1 if the IR reading is greater than or equal to the threshold.
- BYTE Sensor
Range: 0 to 7 - 0=Left, 1=Front Left, 2=Front, 3=Front Right, 4=Right, 5=Rear Right, 6=Rear, 7=Rear Left
LCDPlotPixel
Allows a single pixel on the LCD to be set or cleared.
- BYTE X
Sets the X coordinate - Range 0-127
- BYTE Y
Sets the Y coordinate - Range 0-31
LCDSetBackgroundColour
Sets the pixel colour to drive the LCD. Default colour is 1 where a set pixel is black and the background is white.
- BYTE Colour
Range 0-1 : 0=White, 1=Black
ReadIRSensor
Reads the analogue value from the specified IR distance sensor. Return value range: 0 to 4095 4095 represents the object is very close.
- BYTE Channel
SetMotors
Sets the speed and direction of the Formula Allcode motors.
- INT Left
Valid Range = -100 to 100
- INT Right
LogoBackwards
Drives the robot backward using the encoders as feedback to ensure the robot drives straight. Automatically stops at the specified distance.
- UINT Distance
Distance you want to robot to drive in mm. Range 1-65535
EncoderReset
Resets the encoder counters to 0
Reverse
Drives both motors of the formula flowcode backwards with the power specified.
- BYTE Power
WaitForSwitch
Waits for the specified switch to be pressed.
- BYTE Switch
Which switch do we want to wait for 0=Left, 1=Right, 2=Either, 3=Both
ReadLDR
Reads the current light level from the on board light sensor. Return value range: 0 to 4095 4095 represents the maximum level of light and 0 represents the minimal level of light.
LCDDrawRectangle
Draws a rectange on the LCD.
- BYTE X1
Range 0-127
- BYTE Y1
Range 0-31
- BYTE X2
Range 0-127
- BYTE Y2
Range 0-31
- BYTE Transparent
Sets the transparency of the box, 0=Box contains background colour, 1=Box contains previous pixel data
- BYTE Solid
Chooses to fill the box with colour, 0=Box contains transparency data, 1=Box contains foreground colour
EncoderReadCount
Reads one of the motor encoder counters. Each encoder count is equal to 0.314159 mm.
- BYTE Channel
0 = LeftCount, 1=RightCount
CheckUSB
Checks to see if a USB cable is connected to the robot. Returns 0 for no connection and 1 for an active connection.
LCDSetForegroundColour
- BYTE Colour
Starts up the Formula Allcode PWM for motor control and performs the wait for button press if enabled.
LogoSetSpeed
Sets the cruise speed for LOGO type macros. Default speed 20%.
- BYTE Speed
Range 1-100, Default 60
LogoForwards
Drives the robot forward using the encoders as feedback to ensure the robot drives straight. Automatically stops at the specified distance.
- UINT Distance
LCDClear
Clears the contents of the graphical LCD.
Wait For Button
Determines if the program will automatically wait for one of the front switches to be pressed before executing the program. Ran as part of the initialise function after the various components have been initialised.
Show Creation Info
Specifies what information is shown to the user on calling the initialise function. The time and date shown are the compilation time and date to help pinpoint the firmware version.
Bluetooth Reset
Decides if the Bluetooth data connection can reset the Formula AllCode. Used by mLoader when programming via Bluetooth to allow reprogramming without having to physically touch the robot. To ensure programming security set this option to No.
Use Motor Feedback
Controls when the motor feedback is used. No - Speed control feedback is not used for SetMotors commands. Yes - Speed control feedback is used for the SetMotors commands. SetMotors commands include Forward, Backward, SpinLeft, SpinRight as well as SetMotors itself. Logo functions always use feedback.
IR Thresholds (CheckIR macro)
IR Distance
IR Threshold used with the CheckIR macro
Line Sensitivity
Simulation Properties
Sim Speed (1 - 100)
Sets the simulated amount of movement relative to the speed of the Formula Allcode.
Timer Interval (ms)
Interval in milliseconds between each simulated movement of the Formula Allcode robot.
Collision Method
Select which objects the robot sensors will interact with.
Light Source
Panel object specified as the simulation light source. Used when simulating "find the light" type tasks.
PlayNote
- UINT Note
- UINT Time
LEDOn
- BYTE LED
BluetoothTransmit
- BYTE Data
LCDPrintString
- BYTE X
- BYTE Y
- STRING Data
- UINT Transparent
Stop
Stops both motors.
ReadBattery
- FLOAT Return
LEDOff
- BYTE LED
LCDPrintNumber
- BYTE X
- BYTE Y
- UINT Number
- BYTE Transparent
LEDWrite
- BYTE LED_Byte
ReadMic
AudioQueueLength
AudioAddToBuffer
- UINT Data
ReadSwitch
- BYTE Switch
CheckLine
- BYTE Sensor
AudioStreamControl
- BYTE Mode
- BYTE SampleRate
SpinLeft
- BYTE Power
LogoTurnLeft
- UINT Angle
Forward
- BYTE Power
LCDWriteByte
- BYTE Data
- BYTE X
- BYTE Y
BluetoothReceive
LCDDrawLine
- BYTE X1
Range 0-127
- BYTE Y1
Range 0-31
- BYTE X2
Range 0-127
- BYTE Y2
Range 0-31
- STRING Data
LCDBacklight
- BYTE Brightness
AudioReadFromBuffer
ReadLineSensor
- BYTE Channel
LogoTurnRight
- UINT Angle
SpinRight
- BYTE Power
CheckIR
- BYTE Sensor
LCDPlotPixel
- BYTE X
- BYTE Y
- BYTE Colour
ReadIRSensor
- BYTE Channel
SetMotors
- INT Left
- INT Right
LogoBackwards
- UINT Distance
EncoderReset
Reverse
- BYTE Power
WaitForSwitch
- BYTE Switch
ReadLDR
LCDDrawRectangle
- BYTE X1
Range 0-127
- BYTE Y1
Range 0-31
- BYTE X2
Range 0-127
- BYTE Y2
Range 0-31
- BYTE Transparent
- BYTE Solid
EncoderReadCount
- BYTE Channel
CheckUSB
- BYTE Colour
LogoSetSpeed
- BYTE Speed
LogoForwards
- UINT Distance
LCDClear
Wait For Button
Show Creation Info
Bluetooth Reset
Use Motor Feedback
IR Distance
Line Sensitivity
Sim Speed (1 - 100)
Timer Interval (ms)
Collision Method
Light Source
PlayNote
- UINT Note
- UINT Time
LEDOn
- BYTE LED
BluetoothTransmit
- BYTE Data
LCDPrintString
- BYTE X
- BYTE Y
- STRING Data
- UINT Transparent
Stop
Stops both motors.
ReadBattery
- FLOAT Return
LEDOff
- BYTE LED
LCDPrintNumber
- BYTE X
- BYTE Y
- UINT Number
- BYTE Transparent
LEDWrite
- BYTE LED_Byte
ReadMic
AudioQueueLength
AudioAddToBuffer
- UINT Data
ReadSwitch
- BYTE Switch
CheckLine
- BYTE Sensor
AudioStreamControl
- BYTE Mode
- BYTE SampleRate
SpinLeft
- BYTE Power
LogoTurnLeft
- UINT Angle
Forward
- BYTE Power
LCDWriteByte
- BYTE Data
- BYTE X
- BYTE Y
BluetoothReceive
LCDDrawLine
- BYTE X1
Range 0-127
- BYTE Y1
Range 0-31
- BYTE X2
Range 0-127
- BYTE Y2
Range 0-31
- STRING Data
LCDBacklight
- BYTE Brightness
AudioReadFromBuffer
ReadLineSensor
- BYTE Channel
LogoTurnRight
- UINT Angle
SpinRight
- BYTE Power
CheckIR
- BYTE Sensor
LCDPlotPixel
- BYTE X
- BYTE Y
- BYTE Colour
ReadIRSensor
- BYTE Channel
SetMotors
- INT Left
- INT Right
LogoBackwards
- UINT Distance
EncoderReset
Reverse
- BYTE Power
WaitForSwitch
- BYTE Switch
ReadLDR
LCDDrawRectangle
- BYTE X1
Range 0-127
- BYTE Y1
Range 0-31
- BYTE X2
Range 0-127
- BYTE Y2
Range 0-31
- BYTE Transparent
- BYTE Solid
EncoderReadCount
- BYTE Channel
CheckUSB
- BYTE Colour
LogoSetSpeed
- BYTE Speed
LogoForwards
- UINT Distance
LCDClear
Wait For Button
Show Creation Info
Bluetooth Reset
Use Motor Feedback
IR Distance
Line Sensitivity
Sim Speed (1 - 100)
Timer Interval (ms)
Collision Method
Light Source
