Component: GLCD (SSD1322) Buffered (SSD1322) (Graphical Monochrome)
Revision as of 15:22, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.6
Category Graphical Monochrome
GLCD (SSD1322) Buffered component
Graphical display component based on the SSD1322 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 2K of graphical memory using the microcontroller's RAM memory.
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1322_buffered.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1322_buffered.fcfx
ReadFontWidth
- BYTE Font
- BYTE Character
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
- UINT X1
- UINT Y1
SetDisplayOrientation
- BYTE Orientation
BPlot
- UINT X1
- UINT Y1
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
SetShadeIntensity
Allows the shade intensity to be set allowing for up to 15 different greyscale levels. Range: 1-15 Default: 15
- BYTE Shade
Range: 1-15 / 1=Dim / 15 = Bright
ClearDisplay
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Chip Select (CS)
Chip select output control pin
Data (SD)
Serial data output control pin
Serial Clock (SCK)
Serial clock output control pin
Reset (RST)
Reset control pin
Connection Type
Clock Delay
Number of microseconds to wait after each clock edge. Recommend 1 for faster devices and 0 for slower devices.
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Component Label
Component Label Scale
Physical Orientation
ReadFontWidth
- BYTE Font
- BYTE Character
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
- UINT X1
- UINT Y1
- BYTE Orientation
BPlot
- UINT X1
- UINT Y1
ReadFontStat
- BYTE Font
- BYTE Index
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
SetShadeIntensity
- BYTE Shade
ClearDisplay
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Chip Select (CS)
Data (SD)
Serial Clock (SCK)
Reset (RST)
Reset control pin
Connection Type
Clock Delay
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Component Label
ReadFontWidth
- BYTE Font
- BYTE Character
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
- UINT X1
- UINT Y1
- BYTE Orientation
BPlot
- UINT X1
- UINT Y1
ReadFontStat
- BYTE Font
- BYTE Index
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
SetShadeIntensity
- BYTE Shade
ClearDisplay
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Chip Select (CS)
Data (SD)
Serial Clock (SCK)
Reset (RST)
Reset control pin
Connection Type
Clock Delay
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Component Label
