Component: I2C (CAL) (Misc)
Revision as of 15:22, 20 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Misc
I2C component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the Two Wire I²C peripheral.
Please click here to download the component source project: FC_Comp_Source_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_I2C.fcfx
Slave_Uninit
Uninitialise the Slave
GetValue
Get the Named property value.
- STRING Name
- STRING Return
Transaction_Write
Attempt to write Length number of bytes to the I2C slave from the given Buffer. Ensure that the Buffer is large enough. Returns the number of bytes written, the caller should check that this matches requested Length
- BYTE Buffer
Buffer of bytes to write to the I2C
- UINT Length
Master_Stop
Output a Master Stop
Slave_Init
Initialise the Slave with the given Address, or range of Addresses. Only address bits that have a corresponding bit set in the Mask will be compared with the incoming bus address.
- BYTE Address
7 Bit Address of this device (Bit 0 is ignored)
- BYTE Mask
Bit mask used to compare addresses
Master_Uninit
Uninitialise the Master
Slave_Status
Returns the Slave Status. Bit 0 = 1 Indicates address/data byte available in the buffer to read Bit 5 = 1 Indicates that the last byte received or transmitted was data (else address)
GetConsoleHandle
Obtains the CAL console handle
- HANDLE Return
Slave_TxByte
Send a data byte, returns Ack/Nak from Master 0=Ack=More, 1=Nak=Last
- BYTE Data
Transaction_Uninit
Uninitialise the I2C interface
Slave_RxByte
Returns the data received, and sends either Ack or Nak Set parameter Last as: 1=Last=Nak, 0=Ack=More
- BYTE Last
Sends Ack if 0, else Nak
SetValue
Change Named property to new Value. If "CHANNEL" the ports will be also updated from the fcd
- STRING Name
- STRING Value
port value as string
Master_Init
Initialise the Master
Master_Start
Output a Master Start sequence
Transaction_Read
Attempt to read Length number of bytes from the I2C slave to the given Buffer. Ensure that the Buffer is large enough. Returns number of bytes read, caller should check that this matches requested Length
- BYTE Buffer
Buffer to store the incoming byte data
- UINT Length
Number of bytes to read
Master_TxByte
Send a data byte and collects the acknowledge from the slave. Returns 0 for Ack received. Returns 1 for Ack not received - slave not responding.
- BYTE Data
Data byte to write to the I2C bus
Master_Restart
Output a Master Restart sequence
Master_RxByte
Returns a received data byte. Set Last=0 if there is following more Master_RxByte macros Set Last=1 if this is the last Master_RxByte and it is followed with Master_Stop. If Last = 1 the I2C bus will be presented with a 'Nack' condition.
- BYTE Last
Range: 0-1 - 0 = Not the last byte to receive, 1 = last byte to receive
Transaction_Initialise
Initialise the I2C interface to communicate with a Slave device at Address Returns 0 on fail, 1 on success
- BYTE Address
7-bit I2C Address without the shift for the R/W bit
GetList
returns Named property List as filter string
- STRING Name
- STRING Return
Component Enable
Allows the component to be easily disabled from generating code, allowing for multiple CAL components to be easily created. For example a sensor IC with both I2C and SPI communications interfaces.
Channel selection
Mode
Defines if the component will be used for Master or Slave communications. Master mode supports a software bitbanged I2C channel. Slave mode requires a hardware I2C peripheral to catch the communications from the Master.
SDA
SCL
Options
Stop Delay
Baud Select
Baud rate to be used
Slew Rate Control
Slew Rate Control Enabled or Disabled
SMBus Inputs
When Enabled input logic thresholds are compliant with SMBus specification
API
Specifies the API component on the panel to interact with to provide comms simulation.
Slave_Uninit
GetValue
- STRING Name
- STRING Return
Transaction_Write
- BYTE Buffer
- UINT Length
Master_Stop
Slave_Init
- BYTE Address
- BYTE Mask
Master_Uninit
Slave_Status
GetConsoleHandle
- HANDLE Return
Slave_TxByte
- BYTE Data
Transaction_Uninit
Slave_RxByte
- BYTE Last
SetValue
- STRING Name
- STRING Value
Master_Init
Master_Start
Transaction_Read
- BYTE Buffer
- UINT Length
Master_TxByte
- BYTE Data
Master_Restart
Master_RxByte
- BYTE Last
- BYTE Address
GetList
- STRING Name
- STRING Return
Component Enable
Channel selection
Mode
SDA
SCL
Options
Stop Delay
Baud Select
Slew Rate Control
SMBus Inputs
API
Slave_Uninit
GetValue
- STRING Name
- STRING Return
Transaction_Write
- BYTE Buffer
- UINT Length
Master_Stop
Slave_Init
- BYTE Address
- BYTE Mask
Master_Uninit
Slave_Status
GetConsoleHandle
- HANDLE Return
Slave_TxByte
- BYTE Data
Transaction_Uninit
Slave_RxByte
- BYTE Last
SetValue
- STRING Name
- STRING Value
Master_Init
Master_Start
Transaction_Read
- BYTE Buffer
- UINT Length
Master_TxByte
- BYTE Data
Master_Restart
Master_RxByte
- BYTE Last
- BYTE Address
GetList
- STRING Name
- STRING Return
Component Enable
Channel selection
Mode
SDA
SCL
Options
Stop Delay
Baud Select
Slew Rate Control
SMBus Inputs
API
