Component: IO Expander (PCF8575) (PCF8575) (General Input)
Revision as of 15:22, 20 January 2023 by Wiki bot (talk | contribs)
Category General Input
IO Expander (PCF8575) component
Provides 16 digital input/output pins arranged into 8-bit ports using a I2C bus connection. Up to eight expanders can be connected to the same I2C peripheral by means of three address pins. Supports the PCF8575 device allowing up to 8 expanders to be connected to the same I2C bus.
Please click here to download the component source project: FC_Comp_Source_IOEXP_PCF8575.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_IOEXP_PCF8575.fcfx
ReadPort
Reads the current input value of the I/O pins.
WritePort
Writes an output value to the IO pins
- UINT Value
Value to write. Range 0-65535
I²C Communications
Device Type
External Address
Selects the value of the three address pins for the MCP23S17.
Channel selection
Stop Delay
Baud Select
Baud rate to be used
SDA
SCL
API
ReadPort
WritePort
- UINT Value
I²C Communications
Device Type
External Address
Channel selection
Stop Delay
Baud Select
SDA
SCL
API
ReadPort
WritePort
- UINT Value
I²C Communications
Device Type
External Address
Channel selection
Stop Delay
Baud Select
SDA
SCL
API
