Component: Indicator Meter (Indicators)
Revision as of 15:22, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.5
Category Indicators
Indicator Meter component
Square analogue panel meter. A simulation only component - the needle value is set solely by the 'SetValue' macro.
Please click here to download the component source project: FC_Comp_Source_IndicatorMeter.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_IndicatorMeter.fcfx
SetValue
Set the meter needle to a new position based on the current scaling properties.
- FLOAT Value
Needle position between min and max
Range
Minimum
Minimum value to show on the meter.
Maximum
Maximum value to show on the meter.
Style
BG Color
Color of the meter scale background.
Positive Color
Color of the scale gradations for positive values.
Negative Color
Color of the scale gradations for negative values.
Pointer Color
Label Color
Color of the meter's title label.
Marks
Divisions
Number of large scale divisions..
Subdivisions
Number of sub-divisions in between each major division.
Show
Show or hide the scale markings.
Numbers
Decimals
Number of decimal points to show on scale values.
Text Size %
Text height of the scale values.
Font
Font for the scale value numbers.
Show
Show or hide the scale number values.
Text
A title label to make the meter easier to identify.
Text Size %
Height of the label text.
Font
Font for printing the label.
Show
Show or hide the title label.
SetValue
- FLOAT Value
Range
Minimum
Maximum
Style
BG Color
Positive Color
Negative Color
Pointer Color
Label Color
Marks
Divisions
Subdivisions
Show
Numbers
Decimals
Text Size %
Font
Show
Text
Text Size %
Font
Show
SetValue
- FLOAT Value
Range
Minimum
Maximum
Style
BG Color
Positive Color
Negative Color
Pointer Color
Label Color
Marks
Divisions
Subdivisions
Show
Numbers
Decimals
Text Size %
Font
Show
Text
Text Size %
Font
Show
