Component: Injector (File) (Test Injectors)
Revision as of 15:22, 20 January 2023 by Wiki bot (talk | contribs)
Category Test Injectors
Injector (File) component
Comms data injector to allow data to be streamed to and from a file during simulation. The component will read data from the incoming file and write data to the outgoing file.
Please click here to download the component source project: FC_Comp_Source_InjectorFile.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorFile.fcfx
Example to log the bytes sent via the UART RS232 component to a file as comma separated decimal numbers. LogToFile Contents of the file in the Flowcode project directory after running the simulation.
SPITransferTrans
- BYTE Channel
- UINT Count
- BYTE DataOut
Outgoing data
- BYTE DataIn
Incoming data
UARTBaud
- BYTE Channel
- BYTE Rate
UARTCheckRX
- BYTE Channel
UARTInitialise
- BYTE Channel
SPITransfer
- BYTE Channel
- BYTE DataOut
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
UARTReceive
- BYTE Channel
SPIInitialise
- BYTE Channel
UARTSend
- BYTE Channel
- BYTE Data
Show Console
Incoming File Settings (Rx)
Incoming File
File to stream incoming data from. File -> Communications component.
Parse Mode
Specifies the way we read in the data from the file. Detailed Byte : "z - 122 - 0x7a" Raw : "z" CSV Decimal : "122, " CSV Hex : "0x7a, "
Display Mode
Specifies the way we show the data on the console. Detailed Byte : "z - 122 - 0x7a" Raw : "z" CSV Decimal : "122, " CSV Hex : "0x7a, "
Values Per Line
Number of values to display on a single line of the data console. 0 = Infinite number of characters
Skip Timestamp
A file populated with data from an injector may have a timestamp built in which we may not want to receive. Yes: Skip first 22 characters of each line of data so we don't receive any of the timestamp info. No: Read data normally.
Outgoing File Settings (Tx)
Outgoing File
File to store outgoing data. Communications component -> File
Clear On Init
No - Append to the end of the file. Yes - Empty file on initialise and start from the beginning of the file.
Data Mode
Specifies how the data is represented in the outgoing file. Detailed Byte : "z - 122 - 0x7a" Raw : "z" CSV Decimal : "122, " CSV Hex : "0x7a, "
Values Per Line
Number of values to display on a single line, applies to the file and data console. 0 = Infinite number of characters
Append Timestamp
Appends a timestamp to the beginning of every line relating to the time the first byte in the line was received. Based on the PC system time. Timestamp in the format "YY/MM/DD - HH:MM:SS - "
SPITransferTrans
- BYTE Channel
- UINT Count
- BYTE DataOut
Outgoing data
- BYTE DataIn
Incoming data
UARTBaud
- BYTE Channel
- BYTE Rate
UARTCheckRX
- BYTE Channel
UARTInitialise
- BYTE Channel
SPITransfer
- BYTE Channel
- BYTE DataOut
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
UARTReceive
- BYTE Channel
SPIInitialise
- BYTE Channel
UARTSend
- BYTE Channel
- BYTE Data
Show Console
Incoming File
Parse Mode
Display Mode
Values Per Line
Skip Timestamp
Outgoing File
Clear On Init
Data Mode
Values Per Line
Append Timestamp
SPITransferTrans
- BYTE Channel
- UINT Count
- BYTE DataOut
Outgoing data
- BYTE DataIn
Incoming data
UARTBaud
- BYTE Channel
- BYTE Rate
UARTCheckRX
- BYTE Channel
UARTInitialise
- BYTE Channel
SPITransfer
- BYTE Channel
- BYTE DataOut
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
UARTReceive
- BYTE Channel
SPIInitialise
- BYTE Channel
UARTSend
- BYTE Channel
- BYTE Data
Show Console
Incoming File
Parse Mode
Display Mode
Values Per Line
Skip Timestamp
Outgoing File
Clear On Init
Data Mode
Values Per Line
Append Timestamp
