| Author
Matrix Ltd
| Version
1.2
| Category
Segment
7Segment (Quad) component
14mm seven segment display. LED colour can be set from properties.
Please click here to download the component source project: FC_Comp_Source_LED_7Seg_Quad.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_7Seg_Quad.fcfx
ShowSegments
| Allows the individual segments of the display to be controlled.
- BYTE
Digit
| Which of the four digits to change. (0...3)
- BYTE
Segments
| 8-bit Binary value to set the segments, bit0 = segA, bit1 = segB...
ShowDigit
| Set the number and decimal point to be displayed in the given digit of the display.
- BYTE
Digit
- BYTE
Value
| The number value to set the digit to (0...15), 16=Clear
- BYTE
DecimalPoint
| Whether to show the decimal point for the chosen digit.
Display Type
| Set this according to the specification of your hardware display. Common Anode: Pin true -> LED Off, Pin false -> LED On Common Cathode: Pin true -> LED On, Pin false -> LED Off
Common Type
| The state of the output common pin when the 7-segment display is active. Usually a common cathode display uses a low signal and a common anode uses a high signal. If the common pin is routed via a transistor for power amplification then the signal may need to be reversed.
Show Seg Labels
| Show segment name labels overlayed over the component.
Common Pin 0
| Pin to enable the first digit.
Common Pin 1
| Pin to enable the second digit.
Common Pin 2
| Pin to enable the third digit.
Common Pin 3
| Pin to enable the fourth digit.
Pin0 (A)
| Pin for the 'A' segments of the displays.
Pin1 (B)
| Pin for the 'B' segments of the displays.
Pin2 (C)
| Pin for the 'C' segments of the displays.
Pin3 (D)
| Pin for the 'D' segments of the displays.
Pin4 (E)
| Pin for the 'E' segments of the displays.
Pin5 (F)
| Pin for the 'F' segments of the displays.
Pin6 (G)
| Pin for the 'G' segments of the displays.
Pin7 (DP)
| Pin for the decimal points of the displays.
Colors
LED Color
| Color of the LED segments when truned on. When off, they use a much darker shade of the same hue.
Body Color
| Color of the plastic casing containing the LEDs.
Label Color
| Color for the optional LED segment labels.
ShowSegments
- BYTE
Digit
- BYTE
Segments
ShowDigit
- BYTE
Digit
- BYTE
Value
- BYTE
DecimalPoint
Display Type
Common Type
Show Seg Labels
Common Pin 0
Common Pin 1
Common Pin 2
Common Pin 3
Pin0 (A)
Pin1 (B)
Pin2 (C)
Pin3 (D)
Pin4 (E)
Pin5 (F)
Pin6 (G)
Pin7 (DP)
Colors
LED Color
Body Color
Label Color
ShowSegments
- BYTE
Digit
- BYTE
Segments
ShowDigit
- BYTE
Digit
- BYTE
Value
- BYTE
DecimalPoint
Display Type
Common Type
Show Seg Labels
Common Pin 0
Common Pin 1
Common Pin 2
Common Pin 3
Pin0 (A)
Pin1 (B)
Pin2 (C)
Pin3 (D)
Pin4 (E)
Pin5 (F)
Pin6 (G)
Pin7 (DP)
Colors
LED Color
Body Color
Label Color
