| Author
Matrix Ltd
| Version
1.0
| Category
LEDs
LED Matrix (Parallel) component
LED Matrix component designed to work using multiple data pins and a single clock pin. Each LED on the display can be controlled in a chain by setting the data appropriatley and then generating the appropriate amount of clock pulses.
Please click here to download the component source project: FC_Comp_Source_LED_Matrix_Parrallel.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Matrix_Parrallel.fcfx
Parallel LED matrix example schematic showing 16 LEDs connected using two octal buffer ICs. Data connections to the microcontroller are Data0-Data7, LED_EN, Reset and Clock.
Each clock pulse transfers the output state to the next LED so Data0 goes to LED R0D0 and LED R0D0 goes to LED R1D0 etc.
Example Program
ledmatrixp
Note. to allow the simulation to run smoothly ensure that the simulation speed is set to normal and you may also want to enable hardware acceleration using the Global Options.
Example Panel Display
StrobeHigh
| Sets the strobe pin high. Strobing controls the LED brightness and does not apply to simulation.
StrobeLow
| Sets the strobe pin low. Strobing controls the LED brightness and does not apply to simulation.
DisplayString
| Prints an ASCII string onto the LED Matrix a column at a time.
- STRING
Data
| Data string to display on the LEDs
- UINT
Animation_Delay
| Delay in milliseconds between writing to the next column
- BYTE
Leadout
| Allows the text to scroll completely off the display before returning 0=No, 1=Yes
- BYTE
Add_Spaces
| Add spaces between each ASCII character 0=No, 1=Yes
ClearLEDs
| Sets all of the LEDs in the matrix to the off state.
WriteColumn
| Allows a single column of data to be inserted, Acts to shift the rest of the columns across by one.
- BYTE
Data
| Data to display on the column of LEDs
LED Type
| Active high outputs a logic 1 to set the LED and logic 0 to clear the LED. Active low outputs a logic 0 to set the LED and logic 1 to clear the LED
Row Count
| Number of LED rows
Column Count
| Number of LED columns
LED Count
| Total number of LEDs in the component
Flip Display
| Allows the column and text data sent to the display to be flipped
D0
| Data0 pin which is used to pass the input LED0 value
D1
| Data1 pin which is used to pass the input LED1 value
D2
| Data2 pin which is used to pass the input LED2 value
D3
| Data3 pin which is used to pass the input LED3 value
D4
| Data4 pin which is used to pass the input LED4 value
D5
| Data5 pin which is used to pass the input LED5 value
D6
| Data6 pin which is used to pass the input LED6 value
D7
| Data7 pin which is used to pass the input LED7 value
Clock
| Clock pin used to clock the external buffer IC's
Strobe
| Strobe pin used to control the master display state, strobed at high speed using PWM to set the brightness.
Colours
On Color
| Simulated colour of the LEDs when switched On
Off Color
| Simulated colour of the LEDs when switched Off
Row Spacing
| Simulation row spacing
Column Spacing
| Simulation column spacing
Width
| Simulation LED width
Height
| Simulated LED height
Depth
| Simulated LED Depth (3D environments only)
LED Shape
| Simulated LED basic shape
Redraw LEDs
| Simulated LED redraw option, display will not be updated until the redraw is set to Yes. Automatically revers back to No after the refresh has been performed.
StrobeHigh
StrobeLow
DisplayString
- STRING
Data
- UINT
Animation_Delay
- BYTE
Leadout
- BYTE
Add_Spaces
ClearLEDs
WriteColumn
- BYTE
Data
LED Type
Row Count
| Number of LED rows
Column Count
LED Count
Flip Display
D0
D1
D2
D3
D4
D5
D6
D7
Clock
Strobe
Colours
On Color
Off Color
Row Spacing
Column Spacing
Width
Height
Depth
LED Shape
Redraw LEDs
StrobeHigh
StrobeLow
DisplayString
- STRING
Data
- UINT
Animation_Delay
- BYTE
Leadout
- BYTE
Add_Spaces
ClearLEDs
WriteColumn
- BYTE
Data
LED Type
Row Count
| Number of LED rows
Column Count
LED Count
Flip Display
D0
D1
D2
D3
D4
D5
D6
D7
Clock
Strobe
Colours
On Color
Off Color
Row Spacing
Column Spacing
Width
Height
Depth
LED Shape
Redraw LEDs
