Author
Matrix Ltd
Version
1.1
Category
LEDs
LED Matrix (Serial) component
LED Matrix component designed to work using a single data and clock pin. Each LED on the display can be controlled in a chain by setting the data appropriatley and then generating the appropriate amount of clock pulses.
Please click here to download the component source project: FC_Comp_Source_LED_Matrix.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Matrix.fcfx
StrobeHigh
Sets the strobe pin high. Strobing controls the LED brightness and does not apply to simulation.
StrobeLow
Sets the strobe pin low. Strobing controls the LED brightness and does not apply to simulation.
DisplayString
Prints an ASCII string onto the LED Matrix a column at a time.
- STRING
Data
Data string to display on the LEDs
- UINT
Animation_Delay
Delay in milliseconds between writing to the next column
- BYTE
Leadout
Allows the text to scroll completely off the display before returning 0=No, 1=Yes
- BYTE
Add_Spaces
Add spaces between each ASCII character 0=No, 1=Yes
ClearLEDs
Sets all of the LEDs in the matrix to the off state.
WriteColumn
Allows a single column of data to be inserted, Acts to shift the rest of the columns across by one.
- BYTE
Data
Data to display on the column of LEDs
- BYTE
LED Type
Active high outputs a logic 1 to set the LED and logic 0 to clear the LED. Active low outputs a logic 0 to set the LED and logic 1 to clear the LED
Row Count
Number of LED rows
Column Count
Number of LED columns
LED Count
Total number of LEDs in the component
Flip Display
Allows the column and text data sent to the display to be flipped
Data In
Data In pin which is used to pass the input LED value
Data Out
Data Out Pin - Optional and used to collect the data as it leaves the last buffer
Clock
Clock pin used to clock the external buffer IC's
Strobe
Strobe pin used to control the master display state, strobed at high speed using PWM to set the brightness.
Reset
Reset pin used to clear all of the states in the external buffer IC's
Colours
On Color
Simulated colour of the LEDs when switched On
Off Color
Simulated colour of the LEDs when switched Off
Row Spacing
Simulation row spacing
Column Spacing
Simulation column spacing
Width
Simulation LED width
Height
Simulated LED height
Depth
Simulated LED Depth (3D environments only)
LED Shape
Simulated LED basic shape
Redraw LEDs
Simulated LED redraw option, display will not be updated until the redraw is set to Yes. Automatically revers back to No after the refresh has been performed.
StrobeHigh
StrobeLow
DisplayString
- STRING
Data
- UINT
Animation_Delay
- BYTE
Leadout
- BYTE
Add_Spaces
ClearLEDs
WriteColumn
- BYTE
Data
- BYTE
LED Type
Row Count
Number of LED rows
Column Count
LED Count
Flip Display
Data In
Data Out
Clock
Strobe
Reset
Colours
On Color
Off Color
Row Spacing
Column Spacing
Width
Height
Depth
LED Shape
Redraw LEDs
StrobeHigh
StrobeLow
DisplayString
- STRING
Data
- UINT
Animation_Delay
- BYTE
Leadout
- BYTE
Add_Spaces
ClearLEDs
WriteColumn
- BYTE
Data
- BYTE
LED Type
Row Count
Number of LED rows
Column Count
LED Count
Flip Display
Data In
Data Out
Clock
Strobe
Reset
Colours
On Color
Off Color
Row Spacing
Column Spacing
Width
Height
Depth
LED Shape
Redraw LEDs
