Component: RGB LED WS2801 (LEDs)
Revision as of 15:23, 20 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category LEDs
RGB LED WS2801 component
A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream. Allows RGB LEDs to be driven with full 24-bit colour depth. Allows single chains, 2D arrays and 3D cube formations to be simulated. Supports Bit Banged or SPI peripheral based data modes.
Please click here to download the component source project: FC_Comp_Source_LED_WS2801.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_WS2801.fcfx
1D Configuration
In the 1D configuration each LED simply follows on from the last in a chain.
2D Configuration
In the 2D configuration each LED follows on from the last in a chain which travels back and forth through the columns a row at a time.
3D Configuration
In the 3D configuration each layer follows the 2D configuration with each layer then following on by mirroring the layer below. First layer connections are shown in Red and second layer connections are shown in Blue.
3V3 Microcontrollers
Note you may have to voltage shift the micro controller control pins to meet the 0.8 * VDD minimum requirement. E.g. if VDD is 5V then the input voltage needs to be at least 4V.
A simple buffer IC could be used to do the voltage shifting.
RGB Mood Light
A simple example using three potentiometers to set the individual Red, Green and Blue channels of the LED colour. MoodLight
Animated Light
A simple example which picks a random colour assigns it to the first LED, then shifts and repeats. AnimatedLightStrip
Animated Light Cascade
A simple example which picks a random colour assigns it to the first LED, then shifts and repeats. AnimatedLightCascade
SetBrightness
Allows the output colour brightness of the LEDs to be scaled down. For example to save current usage or to reduce brightness in dark environments.
- FLOAT Scaler
Range: 0.0 to 1.0 Default: 1.0, 0 = Off, 0.5 = Half Brightness, 1.0 = Full Brightness
GetLEDColour
Sets the colour of a single LED in RAM as a 1D array.
- UINT LED
LED to change the colour / Range: 0 to (LED Count - 1)
- BYTE ColIdx
0 = R, 1 = G, 2 = B
SetBrightnessByte
- BYTE Scaler
Range: 0 to 255 Default: 255, 0 = Off, 128 = Half Brightness, 255 = Full Brightness
DrawLine2D
Draws a line on a 2D array of LEDs
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE R
- BYTE G
- BYTE B
SetLEDColour
- UINT LED
- BYTE R
- BYTE G
- BYTE B
SetAllLEDColour
Sets the colour of all the LEDs in RAM
- BYTE R
- BYTE G
- BYTE B
Refresh
Clocks out the current colour data to the LEDs from the values stored in RAM
ShiftLEDs1D
Shifts the LED colours in 1D and wraps
- BYTE Direction
0 = Forwards, 1 = Backwards
- BYTE DataMode
0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
DrawLine3D
Draws a line on a 3D array of LEDs
- UINT X1
- UINT Y1
- UINT Z1
- UINT X2
- UINT Y2
- UINT Z2
- BYTE R
- BYTE G
- BYTE B
GetLEDIndex2D
Sets the index of a single LED in RAM as a 2D array.
- UINT X
LED Column to change the colour / Range: 0 to (LED Column - 1)
- UINT Y
LED Row to change the colour / Range: 0 to (LED Row - 1)
DrawRectangle2D
Draws a basic 2D rectangle onto the LEDs
- BYTE X1
- BYTE Y1
- BYTE X2
- BYTE Y2
- BYTE DrawStyle
Sets the draw style - 0=Soild, 1=Edge, 2=Corners
- BYTE R
- BYTE G
- BYTE B
ShiftLEDs2D
Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
- INT X
Number of pixels to shift the display -1 to 1 / 0 = No Shift
- INT Y
- BYTE DataMode
GetLEDIndex3D
Gets the index of a single LED in RAM as a 3D array.
- UINT X
- UINT Y
- UINT Z
LED Layer to change the colour / Range: 0 to (LED Layer - 1)
DrawCuboid3D
Draws a basic 3D cuboid onto the LEDs
- BYTE X1
- BYTE Y1
- BYTE Z1
- BYTE X2
- BYTE Y2
- BYTE Z2
- BYTE DrawStyle
- BYTE R
- BYTE G
- BYTE B
Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the WS2801 ICs in the chain.
ShiftLEDs3D
- INT X
- INT Y
- INT Z
- BYTE DataMode
LED Properties
LED Arrangement
Controls the arrangement of the LEDs on the panel. 1D - Creates a straight line of LEDs 2D - Creates an X by Y Array of LEDs 3D - Creates an X by Y by Z Array of LEDs
LED Count
Total number of LEDs in the design
LED Columns
Number of horizontal LEDs - X axis
Column Spacing
X Spacing Between LEDs on the Panel
LED Rows
Number of vertical LEDs - Y axis
Row Spacing
Y Spacing Between LEDs on the Panel
LED Layers
Number of LED layers - Z axis
Layer Spacing
Z Spacing Between LEDs on the Panel
Flip X
Flips the X axis if the LEDs are wired from the right hand side of the display.
Flip Y
Flips the Y axis if the LEDs are wired from the bottom side of the display.
Flip Z
Flips the Z axis if the LEDs are wired from the upper most side of the display.
Arrangement
LEDs will likely be arranged in one of two ways. Parallel = Each row of LEDs run from left to right - easier to address but harder to wire. Alternating = Each row of LEDs runs in an alternating direction - harder to address but easier to wire.
Output Mode
Sets the output mode used to drive the data to the LEDs Bit Banged Mode = Allows Any I/O Pin but may be slower SPI Mode = Fixed SPI Peripheral Pins but may be faster - Note that the SPI MISO pin will not be available for general I/O
Connection Properties
Data Pin
LED Data Pin - Connected to the Data In pin of the first WS8201 IC.
Clock Pin
LED Clock Pin - Connected to the Clock In pin of the first WS8201 IC.
API
SetBrightness
- FLOAT Scaler
GetLEDColour
- UINT LED
- BYTE ColIdx
0 = R, 1 = G, 2 = B
SetBrightnessByte
- BYTE Scaler
DrawLine2D
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE R
- BYTE G
- BYTE B
SetLEDColour
- UINT LED
- BYTE R
- BYTE G
- BYTE B
SetAllLEDColour
- BYTE R
- BYTE G
- BYTE B
Refresh
ShiftLEDs1D
- BYTE Direction
- BYTE DataMode
DrawLine3D
- UINT X1
- UINT Y1
- UINT Z1
- UINT X2
- UINT Y2
- UINT Z2
- BYTE R
- BYTE G
- BYTE B
GetLEDIndex2D
- UINT X
- UINT Y
DrawRectangle2D
- BYTE X1
- BYTE Y1
- BYTE X2
- BYTE Y2
- BYTE DrawStyle
- BYTE R
- BYTE G
- BYTE B
ShiftLEDs2D
- INT X
- INT Y
- BYTE DataMode
GetLEDIndex3D
- UINT X
- UINT Y
- UINT Z
DrawCuboid3D
- BYTE X1
- BYTE Y1
- BYTE Z1
- BYTE X2
- BYTE Y2
- BYTE Z2
- BYTE DrawStyle
- BYTE R
- BYTE G
- BYTE B
ShiftLEDs3D
- INT X
- INT Y
- INT Z
- BYTE DataMode
LED Properties
LED Arrangement
LED Count
LED Columns
Column Spacing
LED Rows
Row Spacing
LED Layers
Layer Spacing
Flip X
Flip Y
Flip Z
Arrangement
Output Mode
Data Pin
Clock Pin
API
SetBrightness
- FLOAT Scaler
GetLEDColour
- UINT LED
- BYTE ColIdx
0 = R, 1 = G, 2 = B
SetBrightnessByte
- BYTE Scaler
DrawLine2D
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE R
- BYTE G
- BYTE B
SetLEDColour
- UINT LED
- BYTE R
- BYTE G
- BYTE B
SetAllLEDColour
- BYTE R
- BYTE G
- BYTE B
Refresh
ShiftLEDs1D
- BYTE Direction
- BYTE DataMode
DrawLine3D
- UINT X1
- UINT Y1
- UINT Z1
- UINT X2
- UINT Y2
- UINT Z2
- BYTE R
- BYTE G
- BYTE B
GetLEDIndex2D
- UINT X
- UINT Y
DrawRectangle2D
- BYTE X1
- BYTE Y1
- BYTE X2
- BYTE Y2
- BYTE DrawStyle
- BYTE R
- BYTE G
- BYTE B
ShiftLEDs2D
- INT X
- INT Y
- BYTE DataMode
GetLEDIndex3D
- UINT X
- UINT Y
- UINT Z
DrawCuboid3D
- BYTE X1
- BYTE Y1
- BYTE Z1
- BYTE X2
- BYTE Y2
- BYTE Z2
- BYTE DrawStyle
- BYTE R
- BYTE G
- BYTE B
ShiftLEDs3D
- INT X
- INT Y
- INT Z
- BYTE DataMode
LED Properties
LED Arrangement
LED Count
LED Columns
Column Spacing
LED Rows
Row Spacing
LED Layers
Layer Spacing
Flip X
Flip Y
Flip Z
Arrangement
Output Mode
Data Pin
Clock Pin
API
