Component: Display Manager (Graphical Library)
Revision as of 15:23, 20 January 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Graphical Library
Display Manager component
The component can create the follow objects.
  • Type_Line - 2 - A simple straight line.
  • Type_Rectangle - 1 - A simple rectangular box.
  • Type_RectangeFilled - 5 - A filled rectangular box.
  • Type_Ellipse - 3 - A simple ellipse or circle.
  • Type_EllipseFilled - 4 - A filled ellipse or circle.
  • Type_TextBox - 0 - A text area allowing a line of text to be displayed.
The type can be entered by using the component's public constants. Begin with the Display Manager handle name followed by :: and the list of the public variables will be displayed.
For example... DisplayManager1::Type_TextBox
An example showing the creation of some text areas inside formatted shapes.
Display Manager Example
MoveObject
Moves an existing object to absolute coordinates on the screen.
- UINT ObjectID
- UINT X
- UINT Y
ShiftObject
Shifts an existing object coordinates on the screen relative to the previous coordinates.
- UINT ObjectID
- INT X
- INT Y
DrawObject
Draws a single object onto the display without clearing the display. Doesn't draw a textfield component, this is done using the SetObjectText macro.
- UINT ObjectID
ScaleObject
Changes the width and height of the selected Object
- UINT ObjectID
- UINT Width
- UINT Height
RedrawAll
Redraws all the content from the display manager objects. Doesn't draw textfield components, this is done using the SetObjectText macro.
SetObjectText
Assigns text to a single line text object and draws directly to the display. Blanks the selected area first to ensure nothing from previous text is left behind.
- UINT ObjectID
- STRING Text
- BYTE Font
CreateObject
Define an object on the graphical LCD. Returns the Object ID.
- UINT ObjectType
0=TextBox, 1=Rect, 2=Line, 3=Ellipse, 4=FilledEllipse, 5=FilledRect
- UINT X
X Pixel Coordinate
- UINT Y
Y Pixel Coordinate
- UINT Width
Pixel Width or X Radius
- UINT Height
Pixel Height or Y Radius
LinkTo
Max Objects
The total number of objects allowed on the screen. Sets the size of the RAM buffers used to track the various screen elements.
MoveObject
- UINT ObjectID
- UINT X
- UINT Y
ShiftObject
- UINT ObjectID
- INT X
- INT Y
DrawObject
- UINT ObjectID
ScaleObject
- UINT ObjectID
- UINT Width
- UINT Height
RedrawAll
SetObjectText
- UINT ObjectID
- STRING Text
- BYTE Font
CreateObject
- UINT ObjectType
- UINT X
X Pixel Coordinate
- UINT Y
Y Pixel Coordinate
- UINT Width
- UINT Height
LinkTo
Max Objects
MoveObject
- UINT ObjectID
- UINT X
- UINT Y
ShiftObject
- UINT ObjectID
- INT X
- INT Y
DrawObject
- UINT ObjectID
ScaleObject
- UINT ObjectID
- UINT Width
- UINT Height
RedrawAll
SetObjectText
- UINT ObjectID
- STRING Text
- BYTE Font
CreateObject
- UINT ObjectType
- UINT X
X Pixel Coordinate
- UINT Y
Y Pixel Coordinate
- UINT Width
- UINT Height
LinkTo
Max Objects
