Component: MIAC AllCode (MIAC: PC Peripheral)
Revision as of 15:23, 20 January 2023 by Wiki bot (talk | contribs)
Category MIAC: PC Peripheral
MIAC AllCode component
MIAC AllCode. dsPIC version of the MIAC loaded with the AllCode firmware. Usefull for SCADA, Control or Test applications. Allows you to control the MIAC using the programming language of choice. Compatible with simulation / Bluetooth / Wifi / RS232 and RS485
Please click here to download the component source project: FC_Comp_Source_MIAC_AllCode_Firmware.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MIAC_AllCode_Firmware.fcfx
Bluetooth based examples.
MIAC AllCode Bluetooth
WIFI based examples.
MIAC AllCode WIFI
USB Driver
USB Serial Driver
CommsWrite
Writes a byte to the alt communications channel
- BYTE Data
Range: 0-255
WriteTrans
Allows all transistor outputs to be switched on or off in a single command.
- BYTE Value
Range: 0-15 or 0b0000 to 0b1111
LCDPixel
Controls a single pixel on the MIAC display
- BYTE X
Range: 0-119
- BYTE Y
Range: 0-49
- BYTE State
Range: 0-1
CardCreate
Attempts to create a specific file on the card. Returns 0 for success, 255 for no card or error.
- STRING Filename
CardDelete
Attempts to delete a specific file on the card. Returns 0 for success, 255 for no card or error.
- STRING Filename
LCDBitmap
Draws a bitmap file from the SD card onto the MIAC display
- BYTE X
Range: 0-119
- BYTE Y
Range: 0-49
- STRING Filename
Range: 0-1
GetAPIVersion
Gets the API version of the Robot ARM Firmware
LCDNumber
Prints a number to the MIAC display starting from the current cursor position.
- INT Value
Range: -32678 - 32767
CardInserted
Checks to see if a card is present. Returns 0 for no card or 1 for card detected
ReadRTC
Reads a value from the real time clock module. Used for getting the time or date.
- BYTE Unit
0=Second 1=Minute 2=Hour 3=Day 4=Month 5=Year
CardOpen
Attempts to open a specific file from the card. Returns 0 for file found and opened, 239 for file not found and 255 for no card.
- STRING Filename
CommsRead
Reads a byte from the alt communications channel
- BYTE Timeout
Range: 0-255 : 0 = Don't wait / 1-255 = ms
ReadKey
Reads a keypress from the keypad.
WriteRTC
Writes a value to the real time clock module. Used for setting the time or date.
- BYTE Unit
- BYTE Value
LCDBacklight
Controls the brightness of the LCD backlight.
- BYTE Brightness
Range: 0-100
WriteRelay
Allows a single relay to be switched on or off.
- BYTE Channel
Range 1-4
- BYTE Value
0 = Off, 1 = On
LCDPrint
Prints a string to the MIAC display starting from the current cursor position.
- STRING data
Range: 0-21
LCDLine
Draws a single pixel width line on the MIAC display
- BYTE X1
Range: 0-119
- BYTE Y1
Range: 0-49
- BYTE X2
Range: 0-119
- BYTE Y2
Range: 0-49
ReadInputs
Reads all digital inputs at once and returns as a binary value. Input 1 = Bit 0 Input 8 = Bit 7
CardReadByte
Reads a byte from the open file.
WriteRelays
Allows all relays to be switched on or off in a single command.
- BYTE Value
CardWriteByte
Appends a byte to the end of the open file. Returns 0 for success.
- BYTE data
LCDRect
Draws a single pixel rectangle on the MIAC display
- BYTE X1
Range: 0-119
- BYTE Y1
Range: 0-49
- BYTE X2
Range: 0-119
- BYTE Y2
Range: 0-49
ReadAnalogInput
Reads a single digital input.
- BYTE Channel
CommsBaud
Sets the Baud rate of the alt communications channel
- BYTE Baud
Range: 0-7 : 0=1200 / 7=115200
LCDOptions
Controls some of the LCD options
- BYTE Foreground
Range: 0-1
- BYTE Background
Range: 0-1
- BYTE Transparent
Range: 0-1
LCDVerbose
Controls the Verbose mode. When enabled the LCD automatically displays an account of the incoming API commands and parameters. When switched off the LCD is free for the user to control as required.
- BYTE Mode
Range: 0-1 : 0=Off or User Mode / 1=API Verbose Mode
ReadDigitalInput
- BYTE Channel
PWMConfig
Sets the PWM configuration. Channel = 0 - 1 : 0 = EN_AB, A, B / 1 = EN_CD, C, D Period = 0 - 65535 Scaler = 0 - 3 : 0=1:1 1=1:8 2=1:64 3=1:256
- BYTE Channel
Range 0-1
- UINT Period
Range: 0-65535
- BYTE Scaler
Range: 0-3
PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
PWMDuty
Sets a single PWM channel duty. Channel = 0 - 5 : 0=EN_AB, 1=A, 2=B, 3=C, 4=D, 5=EN_CD Duty = 0 - 65535
- BYTE Channel
Range 0-5
- UINT Duty
LCDCursor
Sets the cursor position for the MIAC display
- BYTE X
Range: 0-21
- BYTE Y
Range: 0-4
WriteTran
Allows a single transistor output to be switched on or off.
- BYTE Channel
Range 1-4
- BYTE Value
0 = Off, 1 = On
LCDClear
Clears the MIAC display
Operating Mode
Mode
Configures how the simulation component functions, does it simply simulate or does it control real hardware.
API Connection Type
API connection mode. COM - Bluetooth / RS232 / RS485 WIFI - Network
AutoDetect Port
Baud
CommsWrite
- BYTE Data
Range: 0-255
WriteTrans
- BYTE Value
LCDPixel
- BYTE X
Range: 0-119
- BYTE Y
Range: 0-49
- BYTE State
Range: 0-1
CardCreate
- STRING Filename
CardDelete
- STRING Filename
LCDBitmap
- BYTE X
Range: 0-119
- BYTE Y
Range: 0-49
- STRING Filename
Range: 0-1
GetAPIVersion
LCDNumber
- INT Value
CardInserted
ReadRTC
- BYTE Unit
CardOpen
- STRING Filename
CommsRead
- BYTE Timeout
ReadKey
WriteRTC
- BYTE Unit
- BYTE Value
LCDBacklight
- BYTE Brightness
Range: 0-100
WriteRelay
- BYTE Channel
Range 1-4
- BYTE Value
0 = Off, 1 = On
LCDPrint
- STRING data
Range: 0-21
LCDLine
- BYTE X1
Range: 0-119
- BYTE Y1
Range: 0-49
- BYTE X2
Range: 0-119
- BYTE Y2
Range: 0-49
ReadInputs
CardReadByte
WriteRelays
- BYTE Value
CardWriteByte
- BYTE data
LCDRect
- BYTE X1
Range: 0-119
- BYTE Y1
Range: 0-49
- BYTE X2
Range: 0-119
- BYTE Y2
Range: 0-49
ReadAnalogInput
- BYTE Channel
CommsBaud
- BYTE Baud
LCDOptions
- BYTE Foreground
Range: 0-1
- BYTE Background
Range: 0-1
- BYTE Transparent
Range: 0-1
LCDVerbose
- BYTE Mode
ReadDigitalInput
- BYTE Channel
PWMConfig
- BYTE Channel
Range 0-1
- UINT Period
Range: 0-65535
- BYTE Scaler
Range: 0-3
PWMEnable
- BYTE EnableMask
PWMDuty
- BYTE Channel
Range 0-5
- UINT Duty
LCDCursor
- BYTE X
Range: 0-21
- BYTE Y
Range: 0-4
WriteTran
- BYTE Channel
Range 1-4
- BYTE Value
0 = Off, 1 = On
LCDClear
Operating Mode
Mode
API Connection Type
AutoDetect Port
Baud
CommsWrite
- BYTE Data
Range: 0-255
WriteTrans
- BYTE Value
LCDPixel
- BYTE X
Range: 0-119
- BYTE Y
Range: 0-49
- BYTE State
Range: 0-1
CardCreate
- STRING Filename
CardDelete
- STRING Filename
LCDBitmap
- BYTE X
Range: 0-119
- BYTE Y
Range: 0-49
- STRING Filename
Range: 0-1
GetAPIVersion
LCDNumber
- INT Value
CardInserted
ReadRTC
- BYTE Unit
CardOpen
- STRING Filename
CommsRead
- BYTE Timeout
ReadKey
WriteRTC
- BYTE Unit
- BYTE Value
LCDBacklight
- BYTE Brightness
Range: 0-100
WriteRelay
- BYTE Channel
Range 1-4
- BYTE Value
0 = Off, 1 = On
LCDPrint
- STRING data
Range: 0-21
LCDLine
- BYTE X1
Range: 0-119
- BYTE Y1
Range: 0-49
- BYTE X2
Range: 0-119
- BYTE Y2
Range: 0-49
ReadInputs
CardReadByte
WriteRelays
- BYTE Value
CardWriteByte
- BYTE data
LCDRect
- BYTE X1
Range: 0-119
- BYTE Y1
Range: 0-49
- BYTE X2
Range: 0-119
- BYTE Y2
Range: 0-49
ReadAnalogInput
- BYTE Channel
CommsBaud
- BYTE Baud
LCDOptions
- BYTE Foreground
Range: 0-1
- BYTE Background
Range: 0-1
- BYTE Transparent
Range: 0-1
LCDVerbose
- BYTE Mode
ReadDigitalInput
- BYTE Channel
PWMConfig
- BYTE Channel
Range 0-1
- UINT Period
Range: 0-65535
- BYTE Scaler
Range: 0-3
PWMEnable
- BYTE EnableMask
PWMDuty
- BYTE Channel
Range 0-5
- UINT Duty
LCDCursor
- BYTE X
Range: 0-21
- BYTE Y
Range: 0-4
WriteTran
- BYTE Channel
Range 1-4
- BYTE Value
0 = Off, 1 = On
LCDClear
Operating Mode
Mode
API Connection Type
AutoDetect Port
Baud
