Component: Robot Arm AllCode SIM (AllCode)
Revision as of 15:24, 20 January 2023 by Wiki bot (talk | contribs)
Category AllCode
Robot Arm AllCode SIM component
Matrix 5-axis Robot Arm with Gripper. Compatible with the Matrix Robot ARM Training Curriculum and Hardware. Features gripper pressure sensor, light sensor, colour sensor, Potentiometer, Magnetic sensor.
Please click here to download the component source project: FC_Comp_Source_RA_Simulation_Source.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RA_Simulation_Source.fcfx
Industrial Tanks
A simple example showing the hoppers, valves and pipes working together. Each tank automatically empties in turn.
Industrial Tanks
LEDOn
Switches on a single LED, LA0-LA7
- BYTE Index
0=LA0, 1=LA1, 2=LA2, 3=LA3, 4=LA4, 5=LA5, 6=LA6, 7=LA7
StoreCoords
Stores the provided coordinates as a position the ARM can recall.
- BYTE Index
Save Index - Range 0-29
- BYTE Position0
Range: 0-180
- BYTE Position1
Range: 0-180
- BYTE Position2
Range: 0-180
- BYTE Position3
Range: 0-180
- BYTE Position4
Range: 0-180
LCDClearLine
- BYTE Line
The line to clear, zero being the first (top) line of the display
LEDOff
Switches off a single LED, LA0-LA7
- BYTE Index
SetMovementSpeed
Controls the speed of the robot movement
- BYTE MovementSpeed
1=Normal Speed (Default), 2=DoubleSpeed
LEDWrite
Allows a value to be sent to control all eight LEDs LA0-LA7 at once
- BYTE Value
(0-63) 0b000000
LinearInterpolation
Moves the robot to the new position so that all axis arrive at the same time.
- BYTE pos0
- BYTE pos1
- BYTE pos2
- BYTE pos3
- BYTE pos4
GripperOpen
Fully opens the gripper at the end of the arm ready to pick something up.
ReadSwitch
Read the value of a single switch. Returns the value as a byte
- BYTE index
0=SA0, 1=SA1, 2=SA2, 3=SA3, 4=SA4, 5=SA5, 6=SA6, 7=SA7
LCDPrintStr
- STRING PrintString
Enter the text or variable to print to the LCD
SetAllServos
Move all the servo positions between 0-180 Deg
- BYTE Servo0_Base
Position of servo0 in degrees (0-180)
- BYTE Servo1_Shoulder
Position of servo1 in degrees (0-180)
- BYTE Servo2_Elbow
Position of servo2 in degrees (0-180)
- BYTE Servo3_Wrist
Position of servo3 in degrees (0-180)
- BYTE Servo4_WristRotate
Position of servo4 in degrees (0-180)
Park
Parks the Robot ARM and switches off the servo motors
StorePosition
Stores the current position of the ARMs 5 axis.
- BYTE Index
ReadPressure
Read the value of the pressure sensor on the ARM gripper. Returns the value as a byte
GotoPosition
Recalls a previously saved position for the ARMs 5 axis.
- BYTE Index
MotorsMoving
Checks to see if any of the motors are still moving.
Beep
Allows the beeper to output a warning
- BYTE Iterations
- UINT OnDelay
Delay in ms
- UINT OffDelay
Delay in ms
SetTrim
Allows minor adjustment on the 5 axis servo motors
- BYTE Index
Motor Index Range 0-4
- BYTE Trim
Amount of Trim Range 0-255, Default Value 128
SetServo
Move the specified servo motor position between 0-180 Deg
- BYTE Index
Range 0-4 : 0=Base, 1=Shoulder, 2=Elbow, 3=Wrist, 4=WristRotate
- BYTE Position
Position of servo in degrees (0-180)
GripperClose
Fully closes the gripper at the end of the arm ready to pick something up. Closes to a defined pressure using the built in pressure sensor. Returns 0 if nothing detected in the gripper Returns 1 if a valid object is detected
- BYTE Pressure
Range 1 - 100, Default Pressure = 20
LCDCursor
- BYTE X
Set the cursor position in the X plane, 0 is the left most cell (0-15)
- BYTE Y
Set the cursor position in the Y plane, 0 is the top most cell (0-1)
LCDPrintNum
Will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT Number
LCDClear
Starting Conditions
LEDOn
- BYTE Index
StoreCoords
- BYTE Index
- BYTE Position0
Range: 0-180
- BYTE Position1
Range: 0-180
- BYTE Position2
Range: 0-180
- BYTE Position3
Range: 0-180
- BYTE Position4
Range: 0-180
LCDClearLine
- BYTE Line
LEDOff
- BYTE Index
SetMovementSpeed
LEDWrite
- BYTE Value
(0-63) 0b000000
LinearInterpolation
- BYTE pos0
- BYTE pos1
- BYTE pos2
- BYTE pos3
- BYTE pos4
GripperOpen
ReadSwitch
- BYTE index
LCDPrintStr
SetAllServos
- BYTE Servo0_Base
- BYTE Servo2_Elbow
- BYTE Servo3_Wrist
Park
StorePosition
- BYTE Index
ReadPressure
GotoPosition
- BYTE Index
MotorsMoving
Beep
- BYTE Iterations
- UINT OnDelay
Delay in ms
- UINT OffDelay
Delay in ms
SetTrim
- BYTE Index
- BYTE Trim
SetServo
- BYTE Index
- BYTE Position
GripperClose
- BYTE Pressure
LCDCursor
- BYTE X
- BYTE Y
LCDPrintNum
- INT Number
LCDClear
Starting Conditions
LEDOn
- BYTE Index
StoreCoords
- BYTE Index
- BYTE Position0
Range: 0-180
- BYTE Position1
Range: 0-180
- BYTE Position2
Range: 0-180
- BYTE Position3
Range: 0-180
- BYTE Position4
Range: 0-180
LCDClearLine
- BYTE Line
LEDOff
- BYTE Index
SetMovementSpeed
LEDWrite
- BYTE Value
(0-63) 0b000000
LinearInterpolation
- BYTE pos0
- BYTE pos1
- BYTE pos2
- BYTE pos3
- BYTE pos4
GripperOpen
ReadSwitch
- BYTE index
LCDPrintStr
SetAllServos
- BYTE Servo0_Base
- BYTE Servo2_Elbow
- BYTE Servo3_Wrist
Park
StorePosition
- BYTE Index
ReadPressure
GotoPosition
- BYTE Index
MotorsMoving
Beep
- BYTE Iterations
- UINT OnDelay
Delay in ms
- UINT OffDelay
Delay in ms
SetTrim
- BYTE Index
- BYTE Trim
SetServo
- BYTE Index
- BYTE Position
GripperClose
- BYTE Pressure
LCDCursor
- BYTE X
- BYTE Y
LCDPrintNum
- INT Number
LCDClear
Starting Conditions
