| Author
Matrix
| Version
1.0
| Category
Sensors
Thermistor Template component
Base component for creating thermistors. Has no GUI - this would be added by concrete examples using this basem which may or may not expose the propertes.
Please click here to download the component source project: FC_Comp_Source_Thermistor_base.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Thermistor_base.fcfx
This example simply reads the value from the thermistor sensor component and outputs the value to an LCD as a temperature in degrees C.
EBM003 Example
GetIntegerTemperature
| Reads the ADC input and returns the calculated Temperature as Integer degrees C
- INT
SetChannel
| Set the ADC Channel
- INT
ChannelID
GetRealTemperature
| Reads the ADC input and Returns the calculated Temperature as Float value in degrees C
- FLOAT
CalculateTemperature
| Converts the input ADC value and returns the Temperature in tenths of degree C
- UINT
ADCValue
| ADC Reading to be converted
- INT
GetADCValue
| Returns the Raw ADC value from the Analogue Channel
- UINT
SetTemperature
| Simulation macro that sets the internal ADC value to the appropriate value for a given temperature. This allows all internal systems of the sensor to be simulated.
- FLOAT
Temperature
| The temperature in C - restricted to -25 to +125 range
ADC Channel
| The ADC channel to which the thermistor circuit is connected. It is assumed that the thermistor is connected between the ADC pin and 0V, with a fixed resistor connected between the ADC pin and +V.
Wiring
| Specifies the arrangement of the Thermistor and Fixed Resistor. Pull Down - Thermistor connected between ADC pin and GND, fixed resistor between ADC pin and VCC. Pull Up - Thermistor connected between ADC pin and VCC, fixed resistor between ADC pin and GND.
ADC Bit Resolution
Resistor Value
| Value in Ohms of the pullup series resistor. i.e. The resistor is connected between the ADC pin and the positive supply rail.
-25C Thermistor Value
| Value in Ohms of the Thermistor at -25 deg C
0C Thermistor Value
| Value in Ohms of the Thermistor at 0 deg C
| Value in Ohms of the Thermistor at 25 deg C
50C Thermistor Value
| Value in Ohms of the Thermistor at 50 deg C
75C Thermistor Value
| Value in Ohms of the Thermistor at 75 deg C
100C Thermistor Value
| Value in Ohms of the Thermistor at 100 deg C
125C Thermistor Value
| Value in Ohms of the Thermistor at 125 deg C
Conversion speed
| Clock setting to select how fast the ADC peripheral will perform an ADC conversion. The FRC setting is based on a RC time base and so will vary with temperature and pressure. Other settings are generally based on divisions of the master clock.
Acquisition cycles
| Number of micro seconds to wait for the ADC input to charge before starting the analogue sample.
VRef option
| Defines what is used as the ADC maximum reference. ADC Range = GND to VRef Voltage VDD - Defines the microcontrollers power supply pin as the max reference, VREF+ Pin - Dedicated pin on the microcontroller to allow for a variable reference voltage.
- INT
SetChannel
| Set the ADC Channel
- INT
ChannelID
GetRealTemperature
- FLOAT
- UINT
ADCValue
- INT
GetADCValue
- UINT
SetTemperature
- FLOAT
Temperature
ADC Channel
Wiring
ADC Bit Resolution
Resistor Value
0C Thermistor Value
Conversion speed
Acquisition cycles
VRef option
- INT
SetChannel
| Set the ADC Channel
- INT
ChannelID
GetRealTemperature
- FLOAT
- UINT
ADCValue
- INT
GetADCValue
- UINT
SetTemperature
- FLOAT
Temperature
ADC Channel
Wiring
ADC Bit Resolution
Resistor Value
0C Thermistor Value
Conversion speed
Acquisition cycles
VRef option
