Component: USB MIDI (Comms: USB)
Jump to navigationJump to search| Author | Matrix Ltd. |
| Version | 1.3 |
| Category | Comms: USB |
USB MIDI component
Component to create and communicate using a standard MIDI connection. Compatible with simulation and USB enabled microcontroller devices. Currently only compatible with the 16-bit PIC range of devices.
Please click here to download the component source project: FC_Comp_Source_USBMIDI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_USBMIDI.fcfx
| SendPitchChange | |
| Sends out a pitch change command on the specified channel. | |
| Channel | |
| Channel to send the pitch change to | |
| Pitch_Change | |
| New pitch value to use, Default 0x2000 | |
| SendNoteOff | |
| Sends a note off command using the channel, note and velocity specified. | |
| Channel | |
| Note | |
| Velocity | |
| SendControl | |
| Sends a control command using the channel, controller and value specified. | |
| Channel | |
| Controller | |
| Value | |
| SendNoteOn | |
| Sends a note on command using the channel, note and velocity specified. | |
| Channel | |
| Note | |
| Velocity | |
| SendPolyPressure | |
| Sends a note press with an associated polyphonic pressure value. | |
| Channel | |
| Note | |
| Pressure | |
| ReadData | |
| Reads a byte from the last received MIDI message | |
| Idx | |
| Byte to read 0-3 | |
| SendPatch | |
| Channel | |
| Instrument | |
| SendChannelPressure | |
| Channel | |
| Pressure | |
| Starts up the USB communications and attempts to enumerate. Returns 0 for a successful startup or 255 for a enumeration timeout. | |
| SendPitchChange | |
| Channel | |
| Pitch_Change | |
| SendNoteOff | |
| Channel | |
| Note | |
| Velocity | |
| SendControl | |
| Channel | |
| Controller | |
| Value | |
| SendNoteOn | |
| Channel | |
| Note | |
| Velocity | |
| Channel | |
| Note | |
| Pressure | |
| ReadData | |
| Idx | |
| SendPatch | |
| Channel | |
| Instrument | |
| Channel | |
| Pressure | |
| SendPitchChange | |
| Channel | |
| Pitch_Change | |
| SendNoteOff | |
| Channel | |
| Note | |
| Velocity | |
| SendControl | |
| Channel | |
| Controller | |
| Value | |
| SendNoteOn | |
| Channel | |
| Note | |
| Velocity | |
| Channel | |
| Note | |
| Pressure | |
| ReadData | |
| Idx | |
| SendPatch | |
| Channel | |
| Instrument | |
| Channel | |
| Pressure | |
