| Author
Matrix TSL
| Version
2.0
| Category
E-blocks 1
Webserver component
Webserver component designed to work with the NM7010A module from Wiznet, as used in the version 1 EB023 E-block. Provides a very simple interface to allow webpages to be hosted from hardware or simulation.
Please click here to download the component source project: FC_Comp_Source_WebServer_EB023-00-1_EB.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WebServer_EB023-00-1_EB.fcfx
SetOutValue
| Set the value of an outbound substitution string
- BYTE
index
- STRING
value
Send_Embedded_HTML_Page4
Send_Embedded_HTML_Page3
Send_Embedded_HTML_Page2
Send_Embedded_HTML_Page1
GetInValue
| Returns the string value of a Request parameter
- BYTE
index
- STRING
CreateServerSocket
| Creates a listening socket on the selected channel and port ready to accept incoming web page requests.
- BYTE
- BYTE
Port_Hi
- BYTE
Port_Lo
- BYTE
IncRxPtr
- BYTE
CheckSocketActivity
| Checks for activity on the server socket and serves out the webpages to any requesting parties.
- BYTE
| Resets and initialises the Internet E-Block. It sets up the gateway address, subnet mask, device IP address and device MAC address as defined in the properties of the Flowcode component. This macro must be called before any other TCP_IP component macros
| Label used to help identify the component on the panel.
Max Channels
| Max number of concurrent channels allowed
I2C Address
| I2C address of the module - bit 0
HTML Source
HTML Source
| Sets the method for streaming data, we can either host it loacally using a property or refer to external files.
Max Pages
| Maximum number of pages we can serve using the embedded page type webserver.
Name Page 1
| Name of HTML page 1 - index.htm is the default page that will be presented.
HTML Page 1
| Embedded HTML code used for page 1
Name Page 2
| Name of HTML page 2
HTML Page 2
| Embedded HTML code used for page 2
Name Page 3
| Name of HTML page 3
HTML Page 3
| Embedded HTML code used for page 3
Name Page 4
| Name of HTML page 4
HTML Page 4
| Embedded HTML code used for page 4
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
Stop Delay
SDA
SCL
Int Pin
| Interrupt pin connection on Wiznet module
Gateway IP
Gateway0
| IP address of the gateway to the internet if applicable.
Gateway1
Gateway2
Gateway3
Subnet Mask
Subnet0
| Subnet mask of the server - usually 255.255.255.0
Subnet1
Subnet2
Subnet3
IP Address
IP0
| IP address of the server - usually 192.168.0.x or 192.168.1.x
IP1
IP2
IP3
MAC Address
MAC0
| MAC address of the server
MAC1
MAC2
MAC3
MAC4
MAC5
Substitutions
Outgoing
Count
| Maximum number of outbound string substitutions
Length 0
| Number of bytes to reserve for data string.
Length 1
Length 2
Incoming
Count
| Maximum number of inbound string substitutions
Length 0
SetOutValue
- BYTE
index
- STRING
value
GetInValue
- BYTE
index
- STRING
CreateServerSocket
- BYTE
- BYTE
Port_Hi
- BYTE
Port_Lo
- BYTE
IncRxPtr
- BYTE
CheckSocketActivity
- BYTE
Max Channels
I2C Address
HTML Source
HTML Source
Max Pages
Name Page 1
HTML Page 1
Name Page 2
| Name of HTML page 2
HTML Page 2
Name Page 3
| Name of HTML page 3
HTML Page 3
Name Page 4
| Name of HTML page 4
HTML Page 4
| Channel selection
Baud Select
Stop Delay
SDA
SCL
Int Pin
Gateway IP
Gateway0
Gateway1
Gateway2
Gateway3
Subnet Mask
Subnet0
Subnet1
Subnet2
Subnet3
IP Address
IP0
IP1
IP2
IP3
MAC Address
MAC0
MAC1
MAC2
MAC3
MAC4
MAC5
Substitutions
Outgoing
Count
Length 0
Length 1
Length 2
Incoming
Count
Length 0
SetOutValue
- BYTE
index
- STRING
value
GetInValue
- BYTE
index
- STRING
CreateServerSocket
- BYTE
- BYTE
Port_Hi
- BYTE
Port_Lo
- BYTE
IncRxPtr
- BYTE
CheckSocketActivity
- BYTE
Max Channels
I2C Address
HTML Source
HTML Source
Max Pages
Name Page 1
HTML Page 1
Name Page 2
| Name of HTML page 2
HTML Page 2
Name Page 3
| Name of HTML page 3
HTML Page 3
Name Page 4
| Name of HTML page 4
HTML Page 4
| Channel selection
Baud Select
Stop Delay
SDA
SCL
Int Pin
Gateway IP
Gateway0
Gateway1
Gateway2
Gateway3
Subnet Mask
Subnet0
Subnet1
Subnet2
Subnet3
IP Address
IP0
IP1
IP2
IP3
MAC Address
MAC0
MAC1
MAC2
MAC3
MAC4
MAC5
Substitutions
Outgoing
Count
Length 0
Length 1
Length 2
Incoming
Count
Length 0
