Component: Webserver (WIZ810MJ) (Comms: Networking)
Jump to navigationJump to search| Author | Matrix Ltd. |
| Version | 2.0 |
| Category | Comms: Networking |
Webserver (WIZ810MJ) component
Webserver component designed to work with the WIZ810MJ module from Wiznet, as used in the version 2 EB023 E-block and MIAC System Industrial Addon. Provides a very simple interface to allow webpages to be hosted from hardware or simulation.
Please click here to download the component source project: FC_Comp_Source_WebServer_WIZ810MJ.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WebServer_WIZ810MJ.fcfx
|   | WM_CH_MR |
|  - BYTE | ch |
|  - UINT | Return |
|   | WM_CH_PORT |
|  - BYTE | ch |
|  - UINT | Return |
|   | WM_TXMEM |
|  - BYTE | ch |
|  - UINT | Return |
|   | MIAC_Module_SetData |
|  - BYTE | Count |
|  - BYTE | D0 |
|  - BYTE | D1 |
|  - BYTE | D2 |
|  - BYTE | D3 |
|  - BYTE | D4 |
|  - BYTE | D5 |
|  - VOID | Return |
|   | WM_CH_RX_RSR |
|  - BYTE | ch |
|  - UINT | Return |
|   | MIAC_Module_GetData |
|  - BYTE | Index |
|  - BYTE | Return |
|   | SetOutValue |
| Set the value of an outbound substitution string | |
|  - BYTE | index |
|  - STRING | value |
|  - VOID | Return |
|   | Send_Embedded_HTML_Page4 |
|  - VOID | Return |
|   | MIAC_Module_Message |
|  - UINT | CAN_ID |
|  - UINT | CMD_ID |
|  - BYTE | Return |
|   | Send_Embedded_HTML_Page3 |
|  - VOID | Return |
|   | Send_Embedded_HTML_Page2 |
|  - VOID | Return |
|   | WM_CH_IR |
|  - BYTE | ch |
|  - UINT | Return |
|   | Send_Embedded_HTML_Page1 |
|  - VOID | Return |
|   | GetInValue |
| Returns the string value of a Request parameter | |
|  - BYTE | index |
|  - STRING | Return |
|   | MIAC_Module_PushData |
|  - BYTE | Data |
|  - VOID | Return |
|   | CreateServerSocket |
| Creates a listening socket on the selected channel and port ready to accept incoming web page requests. | |
|  - BYTE | Channel |
|  - UINT | Port |
|  - BYTE | Return |
|   | WM_CH_CR |
|  - BYTE | ch |
|  - UINT | Return |
|   | WM_CH_TX_WR |
|  - BYTE | ch |
|  - UINT | Return |
|   | IncRxPtr |
|  - BYTE | Channel |
|  - VOID | Return |
|   | CheckSocketActivity |
| Checks for activity on the server socket and serves out the webpages to any requesting parties. | |
|  - BYTE | Return |
|   | WM_CH_SR |
|  - BYTE | ch |
|  - UINT | Return |
|   | WM_RXMEM |
|  - BYTE | ch |
|  - UINT | Return |
|   | WM_CH_MR |
|  - BYTE | ch |
|  - UINT | Return |
|   | WM_CH_PORT |
|  - BYTE | ch |
|  - UINT | Return |
|   | WM_TXMEM |
|  - BYTE | ch |
|  - UINT | Return |
|  - BYTE | Count |
|  - BYTE | D0 |
|  - BYTE | D1 |
|  - BYTE | D2 |
|  - BYTE | D3 |
|  - BYTE | D4 |
|  - BYTE | D5 |
|  - VOID | Return |
|   | WM_CH_RX_RSR |
|  - BYTE | ch |
|  - UINT | Return |
|  - BYTE | Index |
|  - BYTE | Return |
|   | SetOutValue |
|  - BYTE | index |
|  - STRING | value |
|  - VOID | Return |
|  - VOID | Return |
|  - UINT | CAN_ID |
|  - UINT | CMD_ID |
|  - BYTE | Return |
|  - VOID | Return |
|  - VOID | Return |
|   | WM_CH_IR |
|  - BYTE | ch |
|  - UINT | Return |
|  - VOID | Return |
|   | GetInValue |
|  - BYTE | index |
|  - STRING | Return |
|  - BYTE | Data |
|  - VOID | Return |
|  - BYTE | Channel |
|  - UINT | Port |
|  - BYTE | Return |
|   | WM_CH_CR |
|  - BYTE | ch |
|  - UINT | Return |
|   | WM_CH_TX_WR |
|  - BYTE | ch |
|  - UINT | Return |
|   | IncRxPtr |
|  - BYTE | Channel |
|  - VOID | Return |
|  - BYTE | Return |
|   | WM_CH_SR |
|  - BYTE | ch |
|  - UINT | Return |
|   | WM_RXMEM |
|  - BYTE | ch |
|  - UINT | Return |
|   | WM_CH_MR |
|  - BYTE | ch |
|  - UINT | Return |
|   | WM_CH_PORT |
|  - BYTE | ch |
|  - UINT | Return |
|   | WM_TXMEM |
|  - BYTE | ch |
|  - UINT | Return |
|  - BYTE | Count |
|  - BYTE | D0 |
|  - BYTE | D1 |
|  - BYTE | D2 |
|  - BYTE | D3 |
|  - BYTE | D4 |
|  - BYTE | D5 |
|  - VOID | Return |
|   | WM_CH_RX_RSR |
|  - BYTE | ch |
|  - UINT | Return |
|  - BYTE | Index |
|  - BYTE | Return |
|   | SetOutValue |
|  - BYTE | index |
|  - STRING | value |
|  - VOID | Return |
|  - VOID | Return |
|  - UINT | CAN_ID |
|  - UINT | CMD_ID |
|  - BYTE | Return |
|  - VOID | Return |
|  - VOID | Return |
|   | WM_CH_IR |
|  - BYTE | ch |
|  - UINT | Return |
|  - VOID | Return |
|   | GetInValue |
|  - BYTE | index |
|  - STRING | Return |
|  - BYTE | Data |
|  - VOID | Return |
|  - BYTE | Channel |
|  - UINT | Port |
|  - BYTE | Return |
|   | WM_CH_CR |
|  - BYTE | ch |
|  - UINT | Return |
|   | WM_CH_TX_WR |
|  - BYTE | ch |
|  - UINT | Return |
|   | IncRxPtr |
|  - BYTE | Channel |
|  - VOID | Return |
|  - BYTE | Return |
|   | WM_CH_SR |
|  - BYTE | ch |
|  - UINT | Return |
|   | WM_RXMEM |
|  - BYTE | ch |
|  - UINT | Return |
